Copytrans
Posted by: Officer DBL on 04 December 2009
Has anyone used this programme to restore music and photos from an iTouch to a PC that crashed and has had to be reformatted?
The reinstalled iTunes doesn't want to know and keeps warning that it will wipe any data from the Itouch if I proceed. I have already lost enough data without losing the stuff on both of our iTouches, so I am hopeful that Copytrans could be a solution.
Any thoughts/views?
Posted on: 04 December 2009 by Gavin B
Officer
Yes, I've had success with this, although not quite in the same circumstances.
Essentially it allows you to connect the iPod (in my case) to the computer without it doing a sync, and then export the stuff from the iPod into an iTunes library.
I used it to move my things from a small PC disk to an external HDD with much more space.
Look at the iLounge website - that seems to have plenty on the subject.
Gavin
Posted on: 04 December 2009 by Officer DBL
Excellent Gavin, just what I needed - and an informative read too. I will get Copytrans as it does seem to be a well recommended solution.
Thank you
