MS VISTA - Sound recording - YouTube etc ...
Posted by: Chumpy on 23 February 2007
MS VISTA RECORDING SECRET NOW REVEALED!
http://www.downloadsquad.com/2007/01/15/how-to-enable-w...-recording-in-vista/
has info to go into Control Panel – Select Sound thing – Select Recording, and even if says ‘none’, Right-click on background of tab window-thing – select Show Disabled Device(s), then Right-click on Wave Out Mix ans select Enable …
RECORD into e.g. Audacity/CDEX etc/edit ….
or
1 Plug in 3.5mm to 3.5mm stereo line out/line in (with headphones output adaptor for monitoring) stereo jack - TURN VOLUME UP TO AT LEAST 50%.
2 Record using CDEX analogue in - save as WAV to .... (Documents/Received)
3 Open Audacity - Open WAV file above ...
4 Edit-normalise ...
5 Export as WAV.
6 In CDEX, convert WAV to e.g. 320 mp3.
7 This file will be in e.g. MUSIC in MP3 folder.
This is for e.g. internet streaming recording.
For external e.g. TV-radio/tape, use line in from e.g. amplifier instead of 'out/in' adaptor lead combo.
There appears to be a problem with Adobe Flash Player and Vista where web sites will not play Flash related content, even if you follow the link provided and install the player and it said that it was installed.
Navigate to:
C:\Windows\System32\Macromed\Flash
Then right clicked over both 'Flash9b.ocx' and 'FlashUtil9b.exe', and chose properties.
In properties choose the 'security' tab > Click on the 'everyone' account, and the button called 'edit' and then tick the box called 'allow full control' and also choose your own Windows local account name.
Once you have done this for both files run the FlashUtil9b.exe and it should install and update and tell you to restart. Do so and you should find that YouTube and other sites that use flash now work.
http://thevistaforums.com/index.php?act=Search&CODE=sim...782&highlite=youtube
