Lp12's are a pain in the arse...
Posted by: jonni on 18 January 2003
..but are worth it in the end.
just got mine working the best I ever had it and I'm stunned.
I've had a problem with the suspention for a while and discovered this was due to the suspention bolts being slightly bent.Borrowed a special tool from my dealer to straigthen them and got it to bounce perfectly, and belive me it DOES make a large difference.
The suspention needs to go sraight up and down with no judders and needs to float very freely .If not you will suffer from a blurred wobbley sound without deep bass and high smooth treble.Of cource you wont realise thats what you've got until you hear the proper thing.
