SACD playback
Posted by: kevinrt on 01 February 2004
Can someone answer a few queries for me on the SACD format?
I have a couple of SACD hybrid discs (notably DSOTM). If I listen to this on my CD5 NAIT5 am I listening to a new mix, or just the original/most recent stereo one?
If I used a SACD player using only 2 channel playback (ie. connected to my NAIT) would I be listening to a different/improved mix or just the same as on my CD5, all other things being equal (ie. assuming a SCAD player of similar quality to the CD5)?
I'm wondering if there is any benefit from using a SACD player if you do not utilise all of the channels.
Posted on: 01 February 2004 by Jay
You'll be listening to the CD layer which is probably a new mix of the original.
You'd be listening to the SACD layer. I'm not sure whether the 2 channel is just 2 channels of the multi-channel, or if it's a separate mix. I would imagine that the multi and the 2 channel are separate but someone else will know for sure.
There would be if you felt it performed better than your CD player. I would imagine you'd have to spend a reasonable amount to get performance close to your CD5 for 2 channel audio. Oh and invest a shedload in SACD software.
Jay
Posted on: 02 February 2004 by HTK
Stupid question time:
A SACD has a CD layer? So if I feed a SACD into my CD5 it WILL play, but not the SACD layer?
Harry
Posted on: 02 February 2004 by David O'Higgins
Sorry Harry,
Some SACDs have a CD layer, but not all. Be very careful about what you buy.
Posted on: 02 February 2004 by kuma
kevin,
Not sure about DSOTM, but, I have 4 different copies of Roxy Music's 'Avalon'. ( well, 5 really if I count the vinyl )
The original US release version
US remastered HDCD version
Japan remastered HDCD paper sleeve version
and
the latest Sony Hybrid SACD version.
I've thrown 'em on CDX2, and guess what! they all sound different. Even figuring in different output level on a each CD, there are variables on each mastering quality.
I thought the US HDCD version sounded the best and here is a kicker, Sony Hybrid redbook layer sounded like a bad 'SACD' playback. i.e. slow and bloated. Even my mate who was listening from the other room quipped 'what happened to this track? sounds muddy'.
I don't have a good enough SACD player, but SACD/DSD layer on the said disc is supposed to be excellent.
Perhaps it varies by the disc, but so far, a redbook layer on hybrid discs I have tried here does not sound that great compared to either origianl realeases or remastered version.
