Unlock those locking DIN plugs - it's official !
Posted by: Henry Cosker on 26 September 2001
Could this also apply to the much larger and heavier collars that lock the Burndy cables in place? It seems to me that you need to lock the Burndy when you first connect it, because the action draws the plug into the socket. But once connected the collar can be loosened without the plug being drawn out of the socket.
I'm considering trying it, but does anyone think this is inadvisable?
I tried this and found a definite deterioration on both counts. This tweaks not for me
Alex
Trouble is you may fing unlocked Din plug rings will audibly 'RING' unless you tape them up or use a spot of bluetack to damp them
If you undo the screw on the top of the plug the ring can be pulled right back out of the way, the screw can then be replaced. Many of us used this technique to use new style leads with old style kit without faffing about with the ring.
Tony.
Alex
Any readers that can enlighten?
thanks in advance,
dave
I just saw the rings off with a junior hacksaw. It takes about 30 seconds each.
Other readers tempted to use such drastic measures might care to use a cut-off wheel on their dremel.
Rico - SM/Mullet Audio
Henry
If we don't get a response by tomorrow I'll get a factory reply for you (hint Dave or Chris).
Personally, my money's on "NO". To dangerous. maybe I'm wrong though.
BTW, the article you cited , did Roy imply leaving the ring *completely* unlocked or simply ring 's "notch" engaged but still "slack" ?
regards,
dave
[This message was edited by dave simpson on FRIDAY 28 September 2001 at 03:00.]
Care should also be taken with snaic's if you have kids fiddling around.
For those not wishing to unlock rings the important factor is not to twist the plug and lock ring when tightening. We have found that when folks lock the ring without firmly holding the plug body firm, the connection can be locked with a slight twist and pin contact is not as good as it should be.
With the ring unlocked this is avoided.
If using either method, remember to stop when you've gone through the locking ring.
Alex.
ps. If anyone quibbles when you try to flog your old leads just tell them they are certified as better sounding and charge extra for having done the work.
Or cats!!!
- GregB
Insert Witty Signature Line Here
You were right - Burndys are just too heavy, which is what I expected, I suppose.
I have found unlocking does make things a little more involving and open, perhaps, but not night and day, or even afternoon and evening.
Thanks for encouraging a response from Paul at Naim, and thanks, Paul, for your clear guidance.
Henry
Some of my interconnects seem to have enough of a twist in them that they wouldn't stay centered unless the collar was done up.
Still, I'll have to try it some time.
Thanks for filling us in.
cheers, Martin
I also would not want to be the "guinea pig" with *my* cds Burndy... leave it locked.
FYI , I believe it was Mr. Koster that discovered the "DIN centering" phenomenon some five years ago.
regards,
dave
BTW, I am experimenting with these interconnects between my CD5 and my Densen pre - which hates the bog-standard Naim interconnect!
I am most pleased with this upgrade over my Nordost Solar Wind, which gives you the tune, but lacks a bit in the dynamics domain, and in bass punch in comparison.
The Anthems are bleedin' brilliant. Unfortunately they cost 550 GBP for the two pairs that I need!
BTW, sorry for the digression.
It's always a nice day for it, have a good one
Steve
ha no class!
Steve
Just a suggestion, given what its going to cost you to upgrade to those Chord interconnects, wouldn't it be worthwhile also investigating the possibility of changing the Densons for something like a Naim 102/180 (part ex against new) or selling the Densons and going for 82/180 second hand. Or even... changing the CD5/Flatcap/Denson for CDX/102/180 etc. etc.
Not wanting to start a Denson vs Naim war here. Its just that the kind of money you are thinking of spending on interconnects would go a substantial way to getting some great Naim boxes that would just love standard Naim interconnects.
Allan
Nice idea, except that I prefer my Densens to the 102/180 combination. The 102 can be a bit harsh at the top end for my tastes. An 82 would be nice though.
Steve
2. Have you ever tried not posting a smilie somewhere?
Six posts above, not counting my signature.
Steve
--> No smily <--
Steve
Be careful: if the din plug partially falls out and loses ground, it will make horrendous noises that can fry your speakers in a matter of seconds.
In my experience of ripping out all sorts of cables at inappropriate times it is only when the Burndy is pulled out that the speaker frying screetch is emitted. I have left my Burndy well alone. Its like wrestling with a python trying to get that thing to behave.
Alex
