n-Vi speakers
Posted by: JonathanP on 27 January 2007
With my CDS-2 needing to go in for cleaning (hopefully) or transport replacement (maybe more likely), I took the plunge and bought an n-Vi to use as a temporary replacement on the grounds that we are planning on an AV/second system anyway.
Now I am thinking of speakers for when the CDS-2 comes back and the n-Vi goes to the family room. Is everyone here using it with a full n-Sats set? Any other choices/recommendations for consideration? It really would be a dual-use system (DVD and less-serious CD listening).
n-Sats would be an obvious choice, except for a couple of observations:
Firstly, the n-Sub seems to cost almost as much as the other 5 speakers put together which suggests it would not be that well matched, but perhaps I am missing the point.
Secondly, should I be considering something a bit larger for front speakers to give a better sound when used for CD listening? Could the n-Vi actually drive something a bit larger (I did actually plug my Obelisks in directly and it sounded fine, but I did not live with that set-up)? I do not wish to go down the route of adding any extra amplification to this sytem.
Any thoughts much appreciated.
Posted on: 27 January 2007 by Former member
I use the Monitor Audio Silver av set up -silver RS6 floor standing fronts/silver RSLCR center/silverRSFX surround these can go on rear side or back wall,and go flush onto the wall.And the silver RSW 12 SUB .Have alook on there site www.monitoraudio.co.uk i have a pair of Naim SBLs on the front at the moment for a change and the are very good.hope this helps regards munch
Posted on: 27 January 2007 by David Dever
ARIVAs for front LR / n-CENT / n-SATs for surround works as a nice combination, and, depending on the room, may not require a sub (turn bass mix on on the n-Vi and set the center and surrounds to small size).
Posted on: 27 January 2007 by JonathanP
munch,
Are you driving the SBLs directly from your n-Vi? How do they sound with CDs? I woul dhave thought the amplifier would not be quite up to driving that kind of load.
Posted on: 28 January 2007 by Former member
Jonathan they sound bloody good ,i had a friends pair for a week a while back ,Thats what made me get a pair. The n/vi has no probs driving them at all .They do music well but for the total surround the Silver RS6 are better.Regards munch
Posted on: 28 January 2007 by PJT
Caution with the Arriva's - I heard this combo (minus n-sub) at the local dealer, and the Arrivas were almost blown apart - they just didn't sem to be able to handle the heavy load thrown their way. But when a 202/200 was plugged in it was SWEET...
Posted on: 28 January 2007 by David Dever
My first demo of the n/vi was done with the Arriva ,they did the film ok, but i did not like them for music.We then put on a pair of Linns and it came to life.regards munch
Posted on: 29 January 2007 by JonathanP
PJT,
That is indeed a little conerning. Arrivas driven by the n-Vi do not make a good stereo system? Due to the heavy load? It seems abit odd. But supported by munch too. Seems like we should be considering alternatives. I was asking about SBLs more from a driving ability, not a realistic alternative, since they do need positioning accurately and are not exactly easy to find in China....
There must be some well matched speaker sets which would work well both for film and music and yet not be too room or positioning dependent...
Posted on: 29 January 2007 by dan scott
I can vouch for that setup as it's exactly what I use, superb performance! I don;t feel the need for a sub with my AV2 channeling the bass to the Ariva's (The people who live underneath me should be happy with that one!)
I can't comment on how the n-Vi drives the Ariva's however as mine are driven at the moment by a Nait5i (Which handles them perfectly)
Posted on: 29 January 2007 by Former member
The Ariva are a good speaker .but they did not do it for me.You might like them , the only way to tell is have a home dem.A lot of people on here will not even bother with the silver RS6 but they are so good on the end of the n/vi give them a chance, with your ears.regards munch
