Powerline, on a Lavry?
Posted by: Right Wing on 21 May 2010
Hi
Anyone tried this? I have done a search which yields some interesting comments but not much.
Posted on: 21 May 2010 by js
I believe Munch and others are using it that way. The Powerline has worked on everyting I've tried it with.
Posted on: 21 May 2010 by Guido Fawkes
You could sell it and buy a Naim DAC or if that is too expensive then go for a Chordette Gem - adding a PowerLine makes it very expensive and it is already quite pricey - just a thought.
Posted on: 21 May 2010 by Graham Russell
I used a Powerline on my Lavry when I had it. I was a good upgrade.
Posted on: 21 May 2010 by bazz
The Powerline is a nice upgrade on the Lavry. I have two PLs in my active system, found them best placed on Supercap powering Snaxo and Armageddon. If digital was my main source I'd have it on the Lavry instead of the Geddon.
Yo Yo Master has one on his DA11 and is pleased with the result.
Posted on: 21 May 2010 by Right Wing
thanks all. i'll give one a go then.
I'll try it out on my nait xs too.
Posted on: 22 May 2010 by kuma
Like a Linn Lingo, Lavry can use a Powerline.
Posted on: 22 May 2010 by AMA
Kuma, sorry for off-topic. I have Lingo I. Will it benefit from Powerline? I don't want to dig into the guts of Lingo box and cut filter out...
BTW other than input filters is there any other audible advantage with Lingo II?
