How to clean/ maintain the laser lens on CD5?
Posted by: willip on 02 September 2003
May I ask how to clean the lens and make sure it is out of dirt/ dust?
Posted on: 03 September 2003 by willip
Anyone wants to share?
Posted on: 03 September 2003 by joe90
not a good idea to touch the lens.
Best get your dealer to service it.
Joe90
Posted on: 03 September 2003 by KenTo
hi willip,
I use a blower for cleaning the camera lens to blow off the dust on the CD laser lens, and never use anything to touch it.
Posted on: 04 September 2003 by Minky
I find a light rub with 120 grit wet and dry sandpaper usually does the trick Razz
Posted on: 07 September 2003 by bjorne
Willip. I use a discwasher CD lenscleaner. It's a CD with small brushes that you can also wet if you like. I bought it because my CDplayer (Arcam Delta270, Philips transport) started to have problems reading discs. I know many say you shall not touch the lens but I have used it few times, it solved the problem and I also feel that it gives a small soundimprovement. I've had it for 2 years so for me it worked good.
Posted on: 07 September 2003 by joe90
Minky rubs his ear lobes with 120 grit wet and dry to improve his listening ability. The resulting roughness of skin grips the soundwaves as they pass and channels them into his ears... Razz
Posted on: 07 September 2003 by Minky
Joe, if you don't stop spying on me I'll have a restraining order slapped on your arse before you get to the bottom of the ladder Big Grin
How's your 'special' F&P sounding now?
Joe90
The F&P is a piece of crap. The original "gentle Annie" should have been called the "brutal Annie" and my "smart drive" is ironically the dumbest design in the whole milky way. Maybe they call it that because of the way it makes you feel like smartly driving it to the edge of a cliff. Anyway, I can't wait for it to explode so I can piss out the fire and then have it crushed. Next time I will get a front loading AEG or an ASCO.
Who the hell are you Mr 90 ?
Posted on: 08 September 2003 by Rico
Joe90? he's just this dude, you know. Wires above his head, kinda jerky movements... dad wore glasses... didn't he drive a cool car?
Rico - SM/Mullet Audio
Posted on: 08 September 2003 by Minky
Rico,
You wouldn't have a photo of Joe's wee case would you ? You know, the one with the little cutouts for the pistol etc. And what about that twirly thing the dude used to sit in that turned him into a rocket scientist or a plumber and stuff. Cool. Big Grin
A little more refreshing than cables ro stands, what? Cool
Those were exciting times no ? By the time Joe was 12 he had seen more action that most of us will see in a lifetime. Stark contrast to these days where some "men" are still breast feeding at thirty. I wonder what Joe is doing now ? Probably propped up a bar somewhere telling anyone who will listen about all the badass plastic villains he gutted before his balls dropped. Bet he goes home and curls up with a Mattel catalogue. Fair enough. Top minge that Barbie.
I used to dream about Aqua Marina. I bet she's an old fish supper by now though. Frown
Posted on: 08 September 2003 by redeye
[QUOTE]Originally posted by Minky:
Big Grin
Re..Spect!
redeye
Posted on: 09 September 2003 by joe90
Golly gee willickers! Rico has penetrated my secret lair and photographed my stuff.
Now you die...
Who are YOU Mr Minky?
Joe90 (new secret identity coming soon)
Posted on: 09 September 2003 by Rico
Sorry Minky, that's the only Marina I could find - if you wear the right sunglasses and squint hard you might find it appears aqua-marina. Still, the motor's got plenty in common with your aqua-marina.
