Phono to BNC adaptors
Posted by: seagull on 09 June 2003
I've just borrowed a 32.5 to play with (thanks Malcolm) and would like to try my LP12 with it.
Problem being, the phono plugs on the end of the leads do not go into the BNC connectors on the pre amp.
I have had a look at the maplins and farnell sites but am confused about which adaptor I should try. (e.g. phono to bnc plug or socket?)
Help appreciated
Please note this is only a temporary arrangement so spending more than a few quid is not an option.
Posted on: 09 June 2003 by Stephen H
Hi Seagull,
I picked some up from a couple of different local hi-fi shops without too much trouble. All they are are female phono to BNC adaptors (i.e. the phono plug on the cable goes into the back of the adaptor and then you plug into the BNC sockets on the amp).
More than happy to post a set to you as a temporary measure so long as you post them back when you're done.
IIRC they only cost around a fiver anyway.
HTH,
Steve.
PS I only used them as a temporary measure till I could get BNC plugs fitted to the cable so they're not doing anything at the mo.
[This message was edited by Stephen H on MONDAY 09 June 2003 at 16:59.]
Posted on: 09 June 2003 by Frank Abela
The ones from Maplin are pretty good. I've never had a single one go wrong.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 09 June 2003 by garyi
There are only two available in the Maplins shop (in my experience) BNC to phono and Phono to BNC
You want the latter, they are 1.99 each and are the same naim used to supply.
Posted on: 09 June 2003 by syd
Incidentally Russ Andrews also do them for around £6.00 each. I believe they are identical to the ones in Maplins. It pays to shop around.
Yours in Music
Syd
Posted on: 09 June 2003 by Not For Me
Yes, I noticed the RA ones wer 3 x the other stores prices, but you obviouslt get more music, more treble, and everything is just so right!
Some of is stuff is O.K, others a rip off.
Back to the plot, Maplins in Brighton is the answer. female phono socket to mail bnc. When you have got a stable systen, replace the arm lead plugs with solder bnc plugs, as this gives one less break in the chain.
DS
ITC - V/A Battery Park Cologne 3.0
Posted on: 09 June 2003 by seagull
Thanks guys,
should be sorted now, like I said its only a temporary measure. The LP12 is due a service any way so I'll get some put on then.
Posted on: 09 June 2003 by oldie
Hi Seagull
I have a set of Cord leads that I had made up years ago for a Micromega CD player that have Male phono plugs[ 2 into 1 bnc], two separate leads joined at a bnc,but no separate earth lead as per the LP12.I believe that you live in the fair town[city if you wish] of Brighton,If so you can have a loan of them
Drop me a email arthur.bird@tesco.net
Oldie.
Posted on: 10 June 2003 by seagull
Hi oldie,
Thanks for the offer, I don't live in Brighton. I grew up in Worthing and support the Albion hence the nickname.
Posted on: 10 June 2003 by oldie
Hi Seagull,
Albion suporter eh!!
Well I supose we all have our own crosse
to bear Wink
Oldie.
