Which nait?
Posted by: Lars on 14 August 2001
Rgds
Lars
It Kan be done!
Tony.
I've never listened to a nait 1, but I listened to a new style nait 2 with Proac Tablette III speakers and it was great, even though the front end was a rather cheap NAD CD player.
Rgds,
Lars
It Kan be done!
I have a Nait 1 that used to drive my ELS57s better than a Quad 33-303, I had a 4 channel PSU in it for a while till it died and had to be sent for a service, but it still has a home in the kitchen in my second system, and just for the hell of it I connect it to my Arcs and it does a passable job driving them. Thats why it gets my vote, its a cracker of an amp.
pete
Aha, memories⦠the main problem with the Quad is the preamp. The 303 is actually a pretty good power amp, and at one stage there was a bit of a craze for partnering them with Meridian or Crimson preamps (cheap at the time but relatively competent). I remember hooking my old 303 up to a Teac 3340 4 track open reel recorder / mixing desk into a friends Heybrook HB2s, and it really sounded remarkably good. The 303 is bloody robust too, I had stupidly just plonked it down on the carpet for the duration of the session, and was monitoring quite loud throughout, when I came to pack the 303 up later I nearly lost the skin off my fingers it was so bloody hot. The 33 is a really cool looking preamp, I would rate it as a design classic, but it does sound totally dynamically challenged, it is soft and warm with a slow and ill-defined bass. I have a feeling that Quad power amps have been getting progressively worse since the excellent valve 2s, and that they have yet to make a great pre.
Its not the first time I have heard that the Nait 1 is a really good match for Quad 57s, now if I had the spaceā¦.
Tony.
Its not the first time I have heard that the Nait 1 is a really good match for Quad 57s, now if I had the space...
I've tried both amps with the 57s. The Nait 1 works, but the Nait 2 sings. If the Nait 2 came with a configurable phono stage, like the Nait 3, I wonder if I every would have upgraded past the kit I had in 1989 -- LP12/Ittok/K9/Nait 2/Quad ESLs.
Joe
the box for my NAIT 2 says 'NAIT2MM' on the side.
Sort of suggests that MC may also be an option. Sounds interesting if it can!!
cheers, Martin
the box for my NAIT 2 says 'NAIT2MM' on the side. Sort of suggests that MC may also be an option.
I'm pretty sure that the Nait 1 and 2 were MM input only, the logic likely being that if you upgraded to a decent MC cartridge, you'd probably want, say, at least a 42.5/110 or 32.5/110.
Maybe the MM is short for "mmmmmmmmmmmmmmm" as in "mmmmmmmmmmmmmmmmm, Nait."
Joe
I guess this is your way of saying: Welcome to the Forum.
Lars ![]()
It Kan be done!
