Headphones for the Headline
Posted by: Carlos Bento on 08 June 2007
Hi,
What is the best choice for the headline?
For example Sennheiser HD 595, is a good choice?
Best regards,
Carlos Bento
Posted on: 08 June 2007 by u5227470736789439
Dear Carlos,
Welcome to the forum.
May I suggest that that you repost this Thread in the Hifi Corner? Many in the Music Room will not really have an answer to your question, but in the other place you will find many and varied, and often helpful advice. I don't know the answer to your question, sorry...
2 pence worth from Fredrik
