Extreme base update incompatible with iTunes
Posted by: av in bc on 12 March 2009
does anyone else have a problem with the new
firmware (7.4.1) for the Extreme Base Station "n",
where itunes drops audio.
downgraded back to 7.3.2 and everything is fine.
Posted on: 12 March 2009 by Former member
My update worked seamlessly, but if you check the various Apple discussion forums you'll see there have been plenty of problems.
