Naim as guitar amp
Posted by: Ian P on 15 March 2002
Gosh,it's been a while - hope all are well, especially any who remember me !
Some may recall from a while back (if they have very good memories) that I was thinking of taking up guitar. Well I finally did, and am having fun learning on an acoustic.
In fact I'm enjoying it so much I'm thinking of also getting an electric. I'd like to avoid buying anything more than the naked guitar, so am wondering has anyone much experience of using a Naim system for amplification ? Basically, does it work, and what does one need to connect guitar to pre-amp ?
Thanks for any input (no pun intended).
Ian
This way you can take your act on the road
We use one with wireless mics and a CD player.
- GregB
"The Wacky Yo-Yo Man"
There have been previous diatribes from purist about using Naim amps with other pre-amps.
Ignore them.
I did, and np harm has every come of it.
DS
Welcome back! What guitar did you get?
(And, err ..., talk about mocking the afflicted - can you not just say where you're really from?)
Thomas
Originally posted by Thomas K:
Hello Ian,Welcome back! What guitar did you get?
Thomas
The acoustic is a Simon & Patrick SP6 Spruce top. Looks and sounds great.
Sorry about the "old news" location quip, I'll go change that!
Thanks for the advice so far chaps. It sounds like the suggestions involve by-passing the pre-amp section of my system. That isn't a goer - what I was wondering was how to make the electric guitar simply another source into the pre-amp.
Ian
Directly connecting your guitar to a line level channel of your preamp will work, but I think the sensitvity is to low and also you want some processing between guitar output and a hifi approach to amps to get a 'realistic' guitar sound.
Paul
Originally posted by Paul Ranson:
My understanding of the posts is that you install a widget between the guitar and your preamp.Directly connecting your guitar to a line level channel of your preamp will work, but I think the sensitvity is to low and also you want some processing between guitar output and a hifi approach to amps to get a 'realistic' guitar sound.
Paul
Right, thanks for that. Would the previous posters be so kind to confirm whether or not the suggested "widgets" are suitable for connection to the pre-amp line level inputs ? If there are any such devices which don't pose a potential threat to the Naim kit please let me know !(ref "otherwise blown speakers are a likely outcome").
Finally, to show my utter ignorance, why is it that "also you want some processing between guitar output and a hifi approach to amps to get a 'realistic' guitar sound" when I'm intending to amplify a real guitar ?
Ian
In a nutshell, simply amplifying the signal out of the guitar pickup will sound pants. If you are after a 'rock' sound, you need a bit reverb etc. to give it "life and space"
Why not take you guitar to a musical instrument shop and ask to typ a few of these things out ?
Whatever output the pedal or box gives you, a lead can be made up or an adapter to go into the preamp.
Watch the volume though.. Especially with high levels of fuzz and distortion, which Hi-Fi speakers will be upset about (blown tweeters).
I had a Line 6 Pod and a Korg Ax1g to go these types of things into a Behringer mixing desk, into a Naim 250. Works fine.
DS
Steve
Thomas
I have a Nait in my “studio” system, and it works really well. I have the computer, bass fx unit (used mainly to get a little more gain), and a couple of keyboard / beat box kind of things plugged into the Nait via a small rack mixer. This means that if I stick a CD into the computer I can play along with it or play along to the sequencer etc. At the moment I have no recording facility, but as I just play for fun so that is not an issue. Quality hard disk recording is only a decent soundcard away should I ever want top add it.
The Pod guitar processor is the ideal thing if you want a kick ass guitar sound without buying an amp, they are as mentioned above truly excellent. I really want to get a Bass Pod at some point. The Zoom thing I use is a bit lame.
If you are looking for a cheap option I have a Mk 1 Korg Pandora lying about that you could have for fifty quid.
Tony.
How on earth do you play records on your deck?
Must be a bit difficult cuing up track 4 side 2?
DS
How on earth do you play records on your deck?Must be a bit difficult cuing up track 4 side 2?
The hard bit is actually getting the record onto the deck!
Tony.
