Stephen Kovacevich Plays Beethoven
Posted by: Todd A on 19 June 2005
Why not? Yes, I’ve been binging on Beethoven, adding new CDs of his music at an almost alarming rate. But the local CD hut had a sale on EMI and, well, I just couldn’t pass it up. I’m not a newcomer to Mr Kovacevich’s EMI Beethoven: I’ve had the Op 10 and 28 and Op 31 discs for a number of years, and some fine things are to be heard in those two discs. The Op 31 sonatas seem more in tune with this pianist’s style, but even the Op 10 sound nice, except for a somewhat unfortunate opening to the first sonata. He even manages to pull off a good Pastorale. Surely his complete cycle warrants a listen. So I endeavored to do just that.
Relentless. That’s the best way to describe the opening of the first sonata. Kovacevich opens (too) fast and (too) hard and plays the entire first movement that way, with little (or nothing, really) in the way of color, variety, or fun. This isn’t even serious playing; this is borderline fierce, angry playing. No one opens as harshly as does this Angelino. The second movement offers more of the same, and it’s not until the third movement that Kovacevich arrives at something more akin to how almost all others play early Beethoven. The finale is fierce but not as strong – or strongly characterized – as some others. The piano tone fortunately never sounds ugly, and Kovacevich never merely bangs away at the keyboard, but he comes uncomfortably close a few times. Kovacevich manages to make both Annie Fischer and Friedrich Gulda sound downright light-hearted and jolly. I must say, this is something of a disappointment.
The second sonata fares a bit better. While hardly relaxed or jovial, Mr Bishop eases up a bit, to the benefit of the piece to be sure. Come the scherzo, one at last has something with nuance and taste, even if one gets the sense that Kovacevich was not only not smiling when he recorded it, but that he had a scowl. The finale comes off well, with everything appropriately restrained (relative to his earlier manhandling of the music), a few rather pronounced lower register chords notwithstanding.
The third sonata fares best of all. It’s even lighter in tone than its predecessors, though it’s still not light. The work comes across more amiably, with the slow movement more nuanced and the concluding movement actually informed by a bit of charm. But this doesn’t salvage the opening trio of sonatas. As if to utterly dispel any notion of musicians becoming more relaxed or contemplative with age, Mr Kovacevich comes across as basically too aggressive in these early works – and they were recorded in 2003. While I didn’t buy the set believing that I’d hear a new age take, I was a bit taken aback by the fierceness of these works.
That continued with the Op 7. Overbearing is the word that comes to mind. It’s not as relentless as the cycle opener, but it doesn’t feel quite right. While different approaches can certainly be taken – say, a more leisurely, pastoral approach (Kempff), a poetic approach (O’Conor), or an heroic approach (Gulda) – Kovacevich opts for an almost angry approach. He never lets up; passage after angry passage pass with withering effect. He lightens up after the opening movement, but the mood is already a bit spoiled, at least for me. I can handle an intense reading, but I prefer one informed by a different set of priorities.
Perhaps long familiarity with the Op 10 sonatas makes me more accepting of this other early trio, but I think they are more successful than the preceding four works. Kovacevich uses a more flexible approach; he’s not as aggressive; he’s not as uncompromising. One can detect some tenderness – or at least something approximating it – in the slow movements of all the works. One can detect a bit more charm and wit in the concluding movement of the second sonata, though, alas, the repeat is omitted. One can hear foreshadowing of greater things all through the last of the three sonatas. The sort of nonchalant opening to the final movement proves a real treat. And one can hear a more ingratiating tone. Subtle dynamic gradations, appealing piano playing and stylish, subtle pedaling all add to the allure. Yes, this trio of sonatas is altogether more successful.
Kovacevich’s approach works much better in the Pathetique. Here’s a work I thought he should succeed in, his serious, aggressive approach adding to the intensity of the piece. While it does that, the whole thing is not quite as aggressive as I thought it would be. Oh, sure, he pounds out the opening chord strongly, and he builds tension up, but when he proceeds into the faster portions of the work, it’s not with unrestrained fire. That’s good. There’s still some heat, and if ultimately he doesn’t offer the last word in passion and swiftness, his blend of elements works wonderfully. The slow movement sounds exceptional, Kovacevich drawing some fine sounds from the keyboard while avoiding any hint of bang, and the closing movement satisfies. Again, I thought he would tear up the keyboard during the runs, but he holds back just a bit, to the benefit of the piece. All told, this is the best recording up to this point in the cycle, and is one of the better recordings of the Op 13 made in the past couple decades.
I hesitantly approached the Op 14 sonatas. These works wilt under the pressure of intense playing. Fortunately, Mr Kovacevich knows just where to stop. His playing in the first sonata is lighter and cheerier than I expected, though it hardly comes across as sunny. Banging and harshness are held in abeyance, and if perhaps pianistic winks and nods go missing, Kovacevich keeps nice, taut tempi throughout, and imbues the work with a sort of serious energy that actually makes the work attractive. He can’t help adding the occasional hard accent – brief, thundering low register chords ring out from time to time to remind the listener that this is serious business. The second sonata is actually more successful. Kovacevich plays, yes, lyrically in the opening movement. Perhaps he lacks that last bit of grace and suppleness that some others bring, but his fleet, tasteful fingerwork and forward momentum really shine. The second movement is lightly punchy and fun to listen to, with a nicely done heavy chord to end it. The closing movement feels just right in the context of this recording. Not too light, not too heavy, Kovacevich blends everything together in just the right mix. I was pleasantly surprised.
Could Mr Kovacevich keep his streak alive with Op 22? Yes! This is another work that can wilt a bit under intense ivory-tickling, and the pianist seems to understand that. The opening movement is taken at a nice clip, and while a bit of steel can be heard here and there, it is not too brutal. It’s not ideally lyrical, though. In the Adagio, the piano tone and pace of playing satisfy immensely, and both the Menuetto and concluding Rondo keep an appealing sound. Again, some steel can be heard from time to time, and perhaps the playing doesn’t possess that vivacity that animates the best accounts of the piece, but it succeeds. After completing a third of the box, it seems somewhat safe to conclude that Mr Kovacevich hasn’t fully come to terms with the earliest sonatas yet – or at least I haven’t come to terms with his hard playing of them – but as things progress, his always (at least) vigorous, at times hard playing offers a serious, somewhat uncompromising Ludwig van. I can’t say that the recordings offer ideal takes of the works – but then, whose do?
