nStream does not show my folders anymore :-(
Posted by: okli on 11 October 2010
Hi,
Since yesterday the nStream does not show my UPnP Folders view anymore. It goes to the first level of them and then after pressing some item it does nothing. If I try with the remote control everything works ok. I've restarted nstream several times already - the only trick I haven't tried yet is to restart my iPhone completely (need to find the PINs first...). Any hint?
TIA,
Ilko
p.s. forgot to mention - I've restarted the media server, too.
Posted on: 11 October 2010 by okli
At last I solved it by myself after restarting nstream, iphone, rebuilding twonky's db - there was a flac file at the same level as the initial directory structure, i.e dir1, dir2,..., test.flac. This file somehow broke the navigation in nstream (only!) - remote control, songbook didn't experience this issue. So I consider it as another bug in the nstream application. My question again is - is there some official way to report bugs?
Thanks,
Ilko
Posted on: 11 October 2010 by garyi
I think you probably have Winker
Posted on: 11 October 2010 by winkyincanada
UPnP is perhaps mis-named?
Posted on: 12 October 2010 by okli
should be read something like "Folders view as provided by the UPnP server" - actually the other views did work ok (Artist, Album, etc...). Anyway, deleting the file (was a test track) solved the problem, so be careful not to put files at the top level of the servers' directory.
Posted on: 12 October 2010 by fixedwheel
Not mis-named, just mis-remembered.
People seem to believe it stands for Universal Plug 'n Play when it actually stands for Universal Plug 'n Pray
A subtle, but vital, difference. Roll Eyes
John
'Universal' was ommited some time ago... and added now after decade of technical progress... or regress ;-)
