I'm using K20 cable with my Kabers and Nait 5.
What kind of termination would you recommend?
Posted on: 07 June 2002 by mykel
Plugs. They are a banana style that connect at 90 degrees to the cable. This will allow them to lay closer to the speaker and facilitate close to wall placements. Works a charm on my Kan's. I used to use the Linn rhodium plugs, changed over to the naim ones and have smiled ever since.
regards,
michael
