Ittock Arm Cable
Posted by: Sean P on 15 October 2002
Anyone tried a different cable with thier ittock.What were the results. Recommendations welcome.
What type of cable plug is at the base of the ittock.
Sean
Builders started yesterday to convert mt Garage into a hifi room. Impatiently waiting!
Posted on: 15 October 2002 by syd
Hi all
I would also like to know of anybodies experience with replacing the arm cable, especially in regards to dressing it. I was wondering about Russ Andrews Kimber cable arm lead and how it would affect the suspension as I beleive tightening the P-Clip on kimber might not be very good for it.
Yours in Music
Syd
Posted on: 16 October 2002 by Rockingdoc
I use the lightest/cheapest RA/Kimber cable on my Ittok (red/blue weave thing, can't remember the name), because I was having hum problems with my Sugden Masterclass phono-stage. RA supply the cable with an SME plug which seems to fit the Ittok. Cable change didn't affect the LP12 set-up, and didn't really affect the sound much. Probably not worth the effort, although the silver cable could be interesting. (The problem turned out to be a noisey cartridge).
p.s. don't forget that there are two grub screws on the Ittok holding the cable, only undo the lower one.
