LP12 Valhalla Installation
Posted by: mfidelity on 04 February 2004
The Valhalla board on my LP12 has died. My options are to buy another board and replace it myself or take the deck to the closest Linn dealer (200 miles RT)and have them ship the board to Linn for repair.
How easy would it be to replace the Valhalla board for a mechanically challanged person such as myself?
Thanks,
Dave
Posted on: 04 February 2004 by --duncan--
It's a bit harder than wiring a plug, but the principles are the same: meaning it’s not difficult technically but don’t get it wrong… Note that the capacitors in the Valhalla board stay charged for quite some time, so leave a couple of hours after disconnection from the mains before you start work. You also need to find a way of supporting the LP12 so you can work underneath it. Take off the lid and platter and, ideally the arm (easy if you have an ARO Smile ) so you are less likely to break something. Take the baseboard off, if you still have it, support between two tables or similar and illuminate well. You then need to disconnect the input (mains and earth) and output (four thin leads to the motor). These are all connected to the Valhalla board by little grub screws, no soldering is required. Label everything as you go. Ease out the ribbon to the switch - it slides out horizontally. The board itself is held with six plastic lugs - fiddling with long-nosed pliers should find it sitting in your hand. Reverse process with new board! The wires to the motor are very thin: check that you don't miss with the grub screw. Make sure that none of the leads are interfering with the sub chassis 'bounce'. Make especially sure you’ve got good earth connections and away you go. There is a picture of one insitu and some other useful advice regarding disconnecting the Valhalla here. There is lots more advice out there if you search for ‘LP12 set-up’ or similar. Get in touch if you need more help.
As luck would have it, there is a very nice Valhalla board on a well-know auction site right now Wink
duncan
Email: djcritchley at hotmail.com
Posted on: 06 February 2004 by mfidelity
Thanks for the helpful advice!
Posted on: 07 February 2004 by popeye34
I second that run through mfidelity: its very straightforward plug and play.
Warning: do switch the power off , do remember to switch the power off after youve tested it (for example if you dont know if its the motor or the PSU that has failed), otherwise, like me you'll find yourself receiving a shock.
And hopefully a generous member will offer you a nice nearly new board for a few pounds that they have lying around after an upgrade.
Regards,Tim.
Thanks and regards,Tim.
