Which pre are you using and are you still happy as a sandboy with it?
Posted on: 14 January 2002 by Alex S.
I'm as happy as a sandboy whose just landed a part in Dune.
I've got the L100 with the HX1.2 power.
The L100 is obsolete and has no remote so its a bargain s/h. If you have the budget, I'd check out the L300 which has probably arrived in NZ by now. It has remote.
Alex
Posted on: 14 January 2002 by redeye
Alex
Thought so. Do you know if the L100 can be used with a Naim power amp successfully? Did you try it?
Posted on: 14 January 2002 by Martin D
Alex, spoke to them today, L300 in "2-3 months" Naim pre's 82 and 52 "work very well"
