Streaming Spotify to the Uniti
Posted by: IainN on 20 November 2009
After much research I've found what seems the best way to send a Spotify stream to the Uniti from Windows.
I've used dsbridge which can be found here.
Extract the dsbridge files and place them in the Program Files/Spotify folder. You'll also need the lame mp3 encoder dll, make sure it's version 3.98.2 and this also needs to be in the Spotify folder. Read the readme.txt file that comes with dsbridge too.
Once you've done that you can then use the Naim vTuner site to set up an iRadio station. There are instructions here on Malcolm Steward's blog on how to use vtuner.
At the station URL entry on vtuner you need to enter in the format 'http://YOUR IP ADDRESS:8124/, e.g. 'http://192.168.1.1:8124/
The IP address being the one of the machine where Spotify will be streaming from.
Restart Spotify and make sure you select iRadio and Added Stations then the named station you set up on vtuner on your Uniti and off you go.
There might be an issue if the IP address changes I guess, and I may have to assign an IP address from the router.
Posted on: 20 November 2009 by silent tim
sounds pretty simple, will give it a go sometime, cheers for the info Smile
Posted on: 20 November 2009 by Former member
Bloody hard work IF YOU ASK ME.
I just loaded it to Windoz months and months ago click on it choose a tune press play.
Same on my Mac,Choose a tune press play and away you go, Music. Roll Eyes
