Naim Interconnect Cable
Posted by: Goldstar on 14 August 2003
Hello All,
Can anyone offer an explanation as to why the Naim interconnect cable sounds better than some of the most expensive cables. I bought some Kimber KCAG silver cable some years ago and every now and then I try it between source components and my 52 pre.
In every case the Kimber sounds restricted, my wife described it as if someone was strangling the sound.
There is no argument that the Naim cable is best, the question is why? After all, this particular Kimber Silver came top in a Hi-Fi news review some years ago....puzzling.
Posted on: 14 August 2003 by joe90
Now I'm no engineer and this is purely how I understand Naim's approach, based on listening and reading between the lines of various Naim newsletters and their other publications...
Naim transfer signal via a 5-pin DIN system rather than the traditional RCA system.
The advantages of DIN plugs are large. They use only ONE ground pin rather than the two found on RCAs. This allows the signal to be properly referenced to earth throughout the system and avoids modulation distortions created by two ground references, ie RCAs.
The Naim interconnect avoids the garbage caused by those distortions without having to use expensive cable. Therefore the music signal is effectively cleaner because it is not carrying all the noise along with it.
No matter how hard you try, RCA cables suffer from this problem and no one seems to effectively engineer out the initial design flaws.
Naim also point out that systems that claim to be 'star-earthed' internally are wasting their time if they use RCA cables.
Also Naim use the cable as part of the curcuit, at least with regards to their amps, so a much more synergistic design is realised.
There are probably people out there who know 10x what I know and I defer to their judgement, but that's how I understand it.
Joe90
Posted on: 15 August 2003 by Goldstar
Hello Joe 90,
Thanks for the reply, I tried to negate the earth effect by having only one earth wire connected. That is normal Naim DIN at the pre-amp end and the centre pin earth wire connected to only one of the rca plugs at the cd player(an arcam cd 32 fmj.)
So we are still left with the effects of the wire itself, as you say, the Naim input only seems to be optimised for the naim interconnect wire. Still ...Anyone for Kimber Silver?
Regards Robert
Posted on: 15 August 2003 by joe90
I've not heard of anyone getting good results from Kimber. People have tried Nordost and opinions on the results are divided.
Chrod Co. seems to be the best alternative.
And really cheap too.
Kimber probably works great with other kit but not with Naim.
Joe90
