Should I upgrade?
Posted by: NB on 27 January 2002
I have had the equinox's for some time now and with the new Allae's on the scene am wondering if I should trade them in for the Ruarks?
What do you think?
NB
What is wrong with my system? Well when I bought the Ruarks I was happy with the sound but now I feel the system lacks depth and insight into the music. Dont get me wrong the sound is very goos but when I hear other system I realise that my hifi is lacking something. The bass is good but the treble is lacking and the music sounds dull and lifeless.
I have my systemplaced on a Naim Fraim and no I dont have a seperate spur.I have asked an electician if a seperate spur can be installed but the construction of the house restricts this.
NB
regards,
Dev
With the kind of money you have invested in your system, and assuming you are a home owner, investing in a separate mains spur is the best upgrade you can make. If the electrican you called says that your house construction doesn't allow another spur, I can't understand what he's talking about. It takes the addition of separtate Circuit breaker box it shouldn't be impossible.
Peter
I have the dreaded plasterboard walls and floors in my house and that makes running cables to where my Hi-fi is impossible. I will be moving homes soon and it is one of the first things I will look at when I move in.
NB
Simon
But you'd be as sicka s a parrot if you bought new speakers now and they sounded great only to sound less great in the new place.
regards,
Mark
Good advice re the spur I will do it when I have moved house.
I have heard the sbl's with my set up and I found them a little to forward for my liking. I was not convinced that my amp was up to the job of running the sbl's. I would only consider the sbl's if I upgraded the hi-cap and the 180. I think the Allea's would provide for a better balanced system.
NB
