Rega Loudspeaker Break-in
Posted by: Justin on 24 September 2002
Hi,
Wondering from those with rega loudspeakers, how long do they generally take to break in from new?
Judd
Posted on: 24 September 2002 by Mike Sae
Depends if you're running them active wink
Otherwise, 1st gen Juras and current gen Elas took about 2 months of casual play.
After the 1st week of "constipation", the break-in process was quite painless.
