SNAIC confusion
Posted by: Boz on 07 June 2002
Am just about to purchase a mid-80's black/slver 250 which comes, according to the vendor, with "HI-cap connector ( 3 pin XLR to 4 pin DIN )"
I am now very confused as I own a 92/90.3 combination and the SNAIC goes from my Hi-Cap and powers my pre NOT my power amp(obviously the pre then powers the power amp)
Can someone more knowlegeable please help and explain the connection for the nap250 (I know it does not have ability to power a pre itself) and how then you connect the pre (in this case for a short while the 92/hi whilst I wait for a good S/H 82)
I also want to upgrade my Hi-cap SNAICS to Black from the current old grey ones I have, do I need to 4 or 5 pin versions
Boz
David J Bostock
