Speaker links
Posted by: Big Ears on 24 November 2001
Just wondered if anyone has experimented with removing Bi-wired speaker links and replaced them with Naim`s A5? What results/imprivements if any?
Regards Gary
Yessss, I did that. It was one of the first and also one of the most affordable upgrades you can
realise.
I removed the metal bi-wire jumpers from my Kan-II's a few days after I bought 'em.
Replaced it with a short piece of Naca5 (coste me some blood,sweat and tears to bend the stiff naca5
,but...it's very worthwile.
The soundstage become more open,with greater detail,and well, it just sounds more alive and with ease then with the original biwire links.
So, for hardly any costs you get an effective and easy upgrade.
Greetings,
Alco
Would you consider an alternative to NACA5 that is more pliable?
Milan
Well, just a few days ago I did try some other brands cable.
I used a short little piece of Van den Hul "The Clearwater",since I thought:"well, what difference can it make on a 2" long piece of wire"
well, enough,so it seemed!
With the Van den Hull it was as if the Kan's become slower and muddy in the bass. So,it does require a little more fiddeling but it will be worth it,believe me.
I do understand your question, cause I also hate the nac-a5 for it's stiffness. The last couple of weeks I became so irritated with it sometimes,that I even thought about going the 'round-earth' route and (yes!) sell the whole lot and by some good (looking) valve stuff and some nice Italian speakers,or someting like that.
Thank god,I came to my senses just in time
See ya'
Alco
I generaly install 2 banana sets at the speaker end of NACA5. One is soldered at the end for highs and one at the exact distance between sets for lows without cutting the cable. That's the best sounding way i've found. Other ideas?
Emmanuel
[This message was edited by Manu on SATURDAY 24 November 2001 at 22:52.]
[This message was edited by Manu on SATURDAY 24 November 2001 at 22:53.]
If you search through the site,there are pictures of the links described by Emmanuel.
If you can visualise a capital letter "F" where the upright is A5 and the two horizontals are the banana plugs.
The space between the two horizontals = the distance between your speaker terminals.
Chris
On these speakers, the terminals were on a board that was easy to detach from the speaker box. It was a cinch to connect the wires from the speakers to the terminals to the same set of terminals.
Much better sound. Don't biwire NACA5 connected to Naim electronics.
Phil
