Mobile Phone Chargers (not a joke!)
Posted by: Harris V on 12 December 2001
This has got to be one of the weirdest tweaks of all time but i at least am convinced. All you have to do is:
Plug you phone charger into a spare socket next to your naim gear and switch on. Mine is a Siemens, i don't know if it works with other brands.
I have been doing this on and off for a few months now and can definitely notice a difference. The silences are blacker, there is more air to the music and everything is that bit 'purer' (harsh edges are reduced).
I am just guessing but i assume that it is affecting the mains supply, i've heard about this working with microwaves but never phone chargers. I have tried other mains conditioners before but can safely say that this tweak kicks Russ Andrew's ass big time.
I would be very interested to know what you lot think.
Posted on: 12 December 2001 by Steve Toy
The 24 volt mains adaptors that come with my Rega Ear and Fono should do the same trick then.
It's always a nice day for it wink Have a good one! smile
Steve.
It's good to get back to normal. wink
Posted on: 14 December 2001 by Harris V
Come on ya bunch of wussies, who tried it? Doesn't anyone even want to declare it the king of tweaks?
Posted on: 14 December 2001 by Andrew L. Weekes
I reckon your charger could be switch-mode or just filtered.
Are you sure it doesn't affect the system rythmically.
The effects you mention sound like the effects of adding a filter, quieter, smoother, yet less flow.
Andy.
Posted on: 14 December 2001 by Martin C
Hi Harris,
I also have a siemen mobile, in fact, I have 02 at home, mine and my wife's. I tried to plug it in next to the freezer, as I saw the demo for silencer before, the buzzing noise will go instantly after you plug the silencer next to it.
I didn't try to plug next to the mains block for the system yet.
Are you sure it's working?
Before I read your thread, I had decided to order a silencer to see whether it's really worked, they have 14day money back guarantee.
cheers
Martin
Posted on: 17 December 2001 by Harris V
Martin,
Go ahead and order the silencer. I am absolutely 100 % convinced that in my system a bog standard mobile phone charger is the best mains conditioner that I have ever tried because it does not ruin the rhythmical abilities of the system. I have tried the silencer for over 6 months now and remain unconvinced that it does anything worthwhile - but maybe thats because my system does not suffer from a noisy mains in the first place.
I am still using a mains ring rather than a spur and the effect is more noticeable if the charger is plugged in 'upstream' of your system.
I do not think that putting near the fridge will necessarily help mainly because I suspect that the charger is not doing anything clever to suppress noise - but then I don't really know what its doing - only that it works.
Posted on: 29 December 2001 by Andy Moore
Should the charger just be plugged in or actually used to recharge the 'phone???
Andy
Posted on: 31 December 2001 by Derek Wright
Are you running the phone charger with the phone connected
Posted on: 31 December 2001 by garyi
Siemens phone chargers seem to take away some of the treble sweetness, the nokia phone charger is better.
snigger.
