Blimey its flat in Indiana
Posted by: Jono 13 on 02 May 2010
Just back from a trip north of Indianaplois and this is typical of the landscape and roads around there...
Jono
Jono
Posted on: 02 May 2010 by Dan Carney
Certainly much flatter than the Malverns!
Posted on: 02 May 2010 by Jono 13
Also found in Fairmount this gem. Sadly only open Saturdays.
Jono
Jono
Posted on: 02 May 2010 by Clay Bingham
quote:Just back from a trip north of Indianaplois and this is typical of the landscape and roads around there...
They're not called the great plains without reason!
Posted on: 02 May 2010 by Onthlam
quote:Originally posted by Clay Bingham:quote:Just back from a trip north of Indianaplois and this is typical of the landscape and roads around there...
They're not called the great plains without reason!Now, imagine tall grasses for almost a thousand miles in each direction. That's what it would have looked like in the early 1800's.
And.....60000000 Bison roaming those plains.
Posted on: 02 May 2010 by mudwolf
yeah one spring break I drove alone from Ft Collins CO to Detroit where my parents were. Filling up at gas station starting out the electric bank sign flashed a degree less each time it came on. Old timer next to me said "yep, it's gonna be a bad one".
12 Hrs later I slept in De Moines Iowa. In the AM my car started but found that wind chill factor was -50 and I was driving 70. I had full ski wear on inside the car, heater full blast and had to keep it alternating between the floor and dash. Not one hill until I hit Michigan.
Afterwards one friend said you should have put cardboard in front of the radiator to keep heat in the coils. What a 20 year old doesn't know....
Everybody has one of these in the garden.
Jono
Jono
Posted on: 02 May 2010 by Paper Plane
Why?
Posted on: 02 May 2010 by u5227470736789524
quote:Originally posted by Paper Plane:
Why? steve
Posted on: 03 May 2010 by Jono 13
Why?
It's the local style from sheds to enormous barns.
Jono
Posted on: 03 May 2010 by Paper Plane
Ah, I see.
Thanks chaps.
Thanks chaps.
Posted on: 03 May 2010 by Roy T
The Straight (and flat) Story.
