URGENT!!!!!!!!
Posted by: Action on 20 February 2002
eek eek
Plz can someone prevent the iminent murder of my wife??
Apparently the carpet fitters arrive tomorrow....BEFORE my NAC5 cable does .PLZ could someone post the dimensions of said cable??
Posted on: 20 February 2002 by Chris Murphy
15mm wide by 5mm high
Posted on: 20 February 2002 by Action
THANKS
You've just saved a life.
P.S
Wife says thx as well
Posted on: 20 February 2002 by davewarehouse
NACA5 is very stiff, and if using a Naim amp you're gonna need 3.5m/ch...Try Linn K20 if this is a problem, it's plastic sleeving is far more flexible. By the way, there was a topic floating around earlier today (can't remember the title) which stated that Linn cable was a copy of early Naim speaker cable, This doesn't suprise me one bit, allthough I prefered it's sound in my system.
Posted on: 20 February 2002 by Manu
They took all this time to copy the NACA4?
Emmanuel
