New Naim DAC - wishlist
Posted by: likesmusic on 27 February 2009
Hi - I'm new to this forum, but the prospect of a NAIM DAC has really excited me, so firstly I'd like to say thanks to NAIM for evidently listening to their customers, existing and potential, by designing a DAC to meet their needs. In the hope that you're still listening, and things aren't too finalised, can I initiate a discussion about what people want from this product, starting with what (I think) I'd like ...
1. Generous connectivity. I want options to listen to cds, my sky-box, DVD, and direct from my laptop or streamed wirelessly from my pc.
Sure, when everything is ripped, I won't need a cd player, but I've thousands of cds yet to rip, and life is short and anyhow I still buy cds and want to play them straight away, so I'll need and use a cd transport for some time yet. Mine has S/PDIF and TOS outputs.
I've other digital sources (like SKY) that I'd like to be able to listen to through a great DAC (the way Linn have gone with their DS really locks other sources out - £10K for a DAC that you can only use via ethernet is ridiculous!)
2. Wireless streaming. Sure ethernet is better, and I hope you'll have that too, but again, my flat is old, over 2 levels, and laying ethernet cable would require tearing things up - so don't force me to do that, or make me mess around with dodgy ethernet over the mains stuff like Linn do, 'cos I'm not going to right now.
3. Sound quality should be beyond reproach. In particular, the source should not affect it. So, whether the bits come from a pc or a cd transport, if they are the same bits they should sound the same. The DAC should be independent of (reasonable) jitter in the source. A competently ripped cd should sound exactly the same as the same cd played from a competent transport. Presumably to cope with streamed data, the DAC will have memory inside it, out of which the data is clocked; data from other sources could be read into the same buffer. A small delay is quite acceptable. Of course, if you've found another way of insulating the thing from jitter, great - but however you do it, there should be no issues with cables/sources affecting the sound. Obviously, delay wouldn not be acceptable for all sources (ie those that need to sync with video).
3. I would hope you can get it right without having an external powersupply as an upgrade.
What do other people want/expect ...?
A volume control perhaps? (After all, with one it would be pre-amp in it's own right)
Balanced outputs? (Then professional use would be easy)
Posted on: 27 February 2009 by Mike Smiff
Do DVD's sound good on two channel PCM then?
I think most people want high end music from pc/server/hdx/transport/sky box/games console.
I myself will only want one for studio master file via pc/mac and also cd from transport,pc/mac.
With a choice of optical/coax inputs,if they work well usb and ethernet.
Posted on: 27 February 2009 by nkrgovic
You do know that wireless bridges exist?
No wireless if possible, thank you. Keeping the RF noise outside the case is much more important than convenience. I think that, most of us at least, are looking for sound quality first. Besides, a very decent wireless bridge is 50GBP, if you need it.
? On a NAIM?
Let there just be a DIN
Yes, din only would do me just fine too,also a mains earth reference in line with Naim CDP's.
Posted on: 27 February 2009 by 'haroldbudd'
yes some balanced outputs on a Naim would be odd but would open up its use in the studio world a bit more, giving it a larger possible market
Posted on: 27 February 2009 by JYOW
Some of my wild wishes:
1. Ethernet music client
2. No built in hard discs
3. No CD ripper/player
4. iTouch/iPhone controller
5. Clock output
6. support for USB hard discs
7. Squeezecenter or iTunes integration
8. Open platform for plugins
9. Tie in with online services (e.g. Pandora if still exist, RHapsody, last.fm....)
Posted on: 27 February 2009 by nap-ster
What about "sounds great" ?
Posted on: 27 February 2009 by Harry H. Wombat
This is a DAC not a music server. That is the HDX and whatever Naim choose to release in the future. It is a "Bring your own transport/server" device and I hope that is the way it stays.
As such, wish lists are inputs, outputs, frequencies and sound quality (and all the related gubbins such jitter reduction etc)
TV/DVD increases in quality dramatically thru a good DAC so as before my wish list restricts to more than one optical in.
Oh and I forgot. It has to sound world class, make my coffee, create it's own music by communing with the spirits of the dead and cost roughly two bags of crisps.
Posted on: 27 February 2009 by u5227470736789454
You've obviously completely mis-understood the whole DAC discussion
yep I agree, my S/N does very good work in that area
Barrie
...................is DAC short for Do All-things Cheaply then ?
Hoho - if it is not then it should be
Posted on: 27 February 2009 by Edot
I'd like to also see a headphone socket so I can flog the one I have.
Posted on: 27 February 2009 by Guido Fawkes
For the new NAIM DAC - I simply want a DAC - no streaming, no volume control, no headphones, no wireless, in fact no computer audio specific stuff at all and no switch mode PSU - just plain simple connections that one would usually expect from the very best DAC with an option to upgrade with an external PSU like the 555PS.
Keep it simple and just make it the first stand alone DAC that I can enjoy.
The Uniti will do all the other stuff - so make the DAC a DAC. No funny software required,
That's my wish.
ATB Rotf
Posted on: 27 February 2009 by Keith L
Posted Fri 27 February 2009 21:58 Hide Post
Why not give it a proper power supply so that it can work to its full potential without having to spend a further GBP5000?
Posted on: 27 February 2009 by themrock
For me a simple DAC nothing else.
The DAC should be better than the built in off the SN, so that the DAC could be an upgrade option.
payable
No half-case.
Just use the 555PS that is with the CD player - there is no extra expense. I'm quite happy to swap cables - no hassle really.
Naim are bound to make it easy.
It has to sound a hell of lot better than a certain other DAC I've heard demo'd, but it is Naim so I'm sure it will
Posted on: 27 February 2009 by js
Proper PS, LOL. It will have more supply inboard than what many here already have included in the DACs that they're using. I bet it's a linear supply besides.
Of course that doesn't guarantee a thing without a listen.
Posted on: 27 February 2009 by pcstockton
That's my wish.
ATB Rotf
I agree with that... but USB please....
thats all. I couldn't care less about the aesthetics of the box, the colors of the lights.
24/96 USB with a couple of spdif and toslink inputs. RCA and/or DIN output would be just fine.
Personally I am looking for a pure networked music client/streamer, which is basically a DAC with Ethernet connection and a big buffer, or a HDX minus the CD, the screen and the hard disks. All three of which added to the cost and did nothing to the sound.
In my limited ownership of 3 DACs in the past 2 years, and finally settling on a decent sounding streamer, there is a certain “rightness” of a DAC built into a player. In fact, three are people in the Slim Devices camp who own dCS or EMM DACs and think the Transporter is at par with these mega buck DACs.
At least in the early days, Naim advocated on not separating the DAC with the CD player, I now think there may be something to it.
Originally posted by AllenB:
No streaming, no wireless, that's covered by the HDX and now Uniti range and I am sure will be expanded.
Uniti does nothing to most of us who already have a full set of Naim gears. I am not sure if there is anything to be expanded in the Uniti range? It is an all-in-once device.
That's my wish.
ATB Rotf
Rotf, this is not an attack at all, the great Dac battle last night on this forum was so munch fun I made popcorn ! I Agree with everything but ... " in fact no computer audio specific stuff at all .. " . Naim make some fantastic compact disc players which play compact discs really insanely well with no headphone jacks and no streaming and no "computer audio stuff" . If you go to the central Naim website, you can see the different models, I only heard the 555 for about an hour but it was an hour of trying my hardest not to wet my pants. In other words , why do you want a Naim Dac ?
Only the often, but not always great, Dali could paint the expression on my face if I paid a few thousand Pounds/Euros/Canadian dollars for a Naim Dac only to bring it home to discover to my horror that I could not plug my Mac (or someone else, a PC ) into it. I could care less what it looks like (chrome bumper would be sweet though ) but to alienate so many, so instantly, by not at least giving the option to plug in their " computer audio specific stuff ' into it would just be pure crackers-bonkers. I really think Naim has a very tough challenge with this DAC madness , but I think I can , with confidence , believe that they would not make a Dac and release it to the public , if it was not absolutely stellar. Naim was very late to the compact disc player game, but they now make some of the very few truly great CD players on the market, so Naim can take their time as far as I am concerned. I thought my girlfriend was silly when she bought an iPhone from that long and well established mobile phone company called Apple. Then I downloaded the App called "remote " and just grinned with joy that I was using the best remote control ever, and last week even laughed harder when I heard about about Nokia and Microsoft and RIM and all the other smart phone makers launching " App" stores to go along with their " smart" phones, so my only wish for the Naim Dac is that it makes the bits you put into it sound happy-dutch-girl great when they come out as sound, regardless of where those bits come from, which is the point of a Dac. Put as many jacks as you want in the back.
ok pubs are going to close here soon, so I have to step out and get a pint or three in....
oh, and none of the Naim compact disc players I mentioned use switch mode PSU's
joaquim
Posted on: 28 February 2009 by Guido Fawkes
Hi Joaquim
I don't feel under attack from your perfectly reasonable post.
Why do I want a DAC? Simple to play music that I cannot get on CD. A number of artists are now download only - yes I can do my own burn to CD, but I don't really want to.
My preference is to stick them on an iPod Nano (or similar solid state storage device) slot it into a Wadia iTransport (or similar) and play it through a Naim DAC. At this time I'm assuming this will sound really good, but I'll only know for sure when I've heard it.
I don't want the device to have Ethernet connectivity because then it'll be possible to connect it to a network, it'll then need an IP address and associated software and a firewall and .... no, no, no, no .... please not all that stuff .... just a nice simple piece of electronics with the Naim knowhow to make it sound stunning. I thought you could still plug a computer in using the digital out - a USB/Firewire interface would be fine I guess, as it is non-networked - as long as it has no other detrimental effects.
It will take its place in an all Naim system in my home. I have heard all the Naim CD players at one time and another and agree they are superb. They get better as you go up the range and the CD555 is the best music player I've heard - though it is close between it and a top turntable. My CDX2/555PS is going nowhere - it'll continue to play CDs for me. It is a superb player.
For me the Uniti is the perfect system for the office and the new Naim DAC promises to be perfect as an addition to my main system. Assuming the Uniti can straight to the files on an iPod and around the iPod's internal DAC then I can simply plug it in the office or home and hear the music.
Well that's the plan .....
ATB Rotf
Posted on: 28 February 2009 by Harry H. Wombat
Ah yes, forgot about that! Two opticals and a USB.
Is there a consensus as to whether USB or Firewire is better (yes I know FW400 is all but obsolete). Have read various things but never really found out if there is a difference.
How about FW800?
Anybody had any experience or views on i2s and/or clock input?
Posted on: 28 February 2009 by nkrgovic
While I agree on the "no streaming, no volume control, no headphones", and the whole "just make it sound great" idea, I would like to remind you that you can leave the network cable unplugged
While it is possible you're right, and we will not see a network port, probably because of the cost, I still think it would be a good add-on. And there should be no interference from an unused network port
Posted on: 28 February 2009 by js
A network attachment would need an inboard player with a way to control it. That's a lot more than a DAC.
Posted on: 28 February 2009 by natnc
How about an HDMI input for getting high resolution 2 channel audio from bluray and other hires formats? The new Oppo bluray will output hires PCM from bluray, SACD and possibly DVD-audio.
Just a thought.
Nat
