motor home
Posted by: scottyhammer on 26 September 2007
hi all,
we as a family want to tour round france next summer in a mobile home or motor home, not sure what they are called. anyway can anyone recommend somewhere in the essex region where i can rent one ?
cheers, scotty
Posted on: 26 September 2007 by hungryhalibut
Have you tried here...
http://www.chariotsmotorhomehire.co.uk/
I have no idea if they are any good, but they look OK. Try googling 'motorhome hire in essex' - that's all I did.
Nigel
Posted on: 26 September 2007 by Derek Wright
Scotty - if you rent one in France you will get a left hand drive which could well be a lot less strain to drive apart from avoiding changing gear with the window winder. You can then balance the cost of transporting a UK van across the channel compared to the cost of shipping the Hammer and Nails across to the part of France where you will pick up the motor home.
Posted on: 27 September 2007 by scottyhammer
hi derek,
i dont see the gears as a problem as ill get an automatic gearbox. left hand drive would be useful i agree BUT ive driven my right hooker car through france without problems.
thanks for the advice though.
nigel, cheers mate -they are quite close to me so ill pop along and have a look.
scotty
