Grills?!
Posted by: Reto D on 25 April 2002
Hi,
I'm a bit confused wheter I shall take off the grills. My dealer recommend me not to do so and told me that the speakers are made to work with them. What do you all think or what experience do you have. Perhaps it depends on the speakers?
Of course I tried it already out and had a rather
positive feeling.
Any advice. Thank you.
Reto
CDX, NAC102, NAPSC, Hi-Cap, NAP 250, ProAc Response 2.5
Posted on: 25 April 2002 by jpk73
Some speakers (sbl, dbl) are designed to work with grills, if I remember correctly...
- Jun
Posted on: 25 April 2002 by Arthur Bye
I've got ProAc's and they work better without the grills. Just take them off and listem to the tweeters.
Arthur Bye
Posted on: 25 April 2002 by Greg Beatty
Remove de grills from dem ProAcs.
- GregB
Response 2 Owner
Posted on: 25 April 2002 by Hammerhead
You've got to keep them outside. I've found they tend to smoke up the listening room something rotten otherwise!
Steve
Taking it all seriously big grin
Posted on: 27 April 2002 by J.N.
Grilles on.
Posted on: 27 April 2002 by JosephR
Originally posted by J.N.:
Grilles on.
http://naim-audio.infopop.net/1/OpenTopic/s/67019385/a/ga/ul/7121981264/The_listening_position.jpg
What are those behind the speakers ? Those aren't curtains, right ?
Well spotted.
They are acoustic panels from RPG.
Check them out at www.rpginc.com
UK supplier is: Acoustic GRG Products in West Hythe Kent. 01303 230944. brian.moule@btinternet.com
Brian and Anita are very helpful.
I went for the 'Studio in a box' package of various sized panels.
Around £300 in bare acoustic foam or £700, cloth covered (which I have).
