Will Naim ever make a decent subwoofer
Posted by: Dev B on 21 April 2001
Self powered of couse with the speed to match properly with Naim speakers.
I think amongst Naim users this could be quite a popular product.
Views or thoughts?
cheers
Dev B
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Arthur Bye
Come on, we all dream of a pair of active DBL's ![]()
Bernard
Rumour has it that Darth Vadar was buried in one of those muthas.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
So how about a naim designed sub - with a 250 inside a sealed cabinet and one of the DBL's 15in drivers. Yours for £2.5k.
I did a search and it seems that a few people have used a REL sucessfully (Jawed and Paul Murray). I suppose I could borrow one from Robert Ritchie as a try out - he has some sort of REL Q200E in the shop.
Dev
Darth Vadar (and his brother) are alive and kicking in in my living room, looking remarkably like a pair of Watt monitors/Puppy subs.
Don
Surprised (and pleased)to find another Watt/Puppy user on this forum. Do you use Naim amps? Have you had any of the Wilson upgrades?
Malcolm
I've had the Watt V/Puppy 2 combination for 2 years now, after Isobariks for about 20 years. I bought them second hand, in gloss black. They were clearly better than any of the competition at that time and IMHO still are.
The Watts are connected with reverse polarity to the Puppies; and the puppies with reverse polarity to the power amps via the main input to the puppy crossover. The watt/puppy connection is via MIT cables. The puppies 'have paws' or 'acoustical diodes' ie spiked feet with spacers. I'm not aware of any other mods-please elaborate.
I use NAC5 cable (10m) to connect them to a pair of 135s/SuperCap/52/CDS1 all on BASE stands and IMHO the system sounds superb, much more dynamic, spacious and powerful than the Briks with excellent tonality of musical instruments and voices.
However, I still feel that a more powerful amp is needed than the 135s to eliminate some 'shouting' eg with female vocalists at high listening levels and to drive the bass with more authority. I had intended to find a second hand Krell FPB 200 or 300, but then along came the NAP500 which does eliminate that 'shouting' etc when driving B&W N802s so might also drive the Watt/Puppies but will add another £5k to bill!
At present I have a recently serviced 250 doing nothing and I keep wondering whether to try bi-amping (but Wilson won't tell me how to do this safely, saying it won't sound right) or whether to get a Naxo/hicap and try an active set-up - any adivce welcome.
What are you driving your speakers with and how do they sound?
Don
RELs still represent superb vfm and performance, and will work exceptionally well - however, the Q200E is not the REL to accompany a decent Naim system with - think more along the lines of Studio or Stentor; they may not appear to be much more powerful (they are, but in different ways) but they are subtle and fast (if located and tuned properly) and produce the deepest bass I've ever heard in-room.
However, they seem to work best with standmounts - full range speakers may have a degree of overlap in the roll-off and therefore you could end up with too much bass. A lot of time spent positioning and tweaking levels is required.
There's a tiny band of 'in tune' with a decent sub, but in that small zone, magical things can happen. However, don't expect magic from cheaper subs, e.g. the Q200E, however great it is for movies... likewise the Linn Seizmik, which was very, very, very disappointing (I heard it for the first time last week and couldn't believe that Linn are asking what they are for it- utterly destroyed by any decent REL!)
ANyway, off for a cuppa,
John
I know you'll say try it and see but I'm wondering if I should be bothered
And. . . please excuse my ignorance, but how would I connect the thing?
At first I had 72/hicap/140, but this was clearly outclassed by the Wilsons and sounded very 'shouty' due to lack of power. I then went into big Americana amps and was never happy. I now use Sugden Masterclass, which sound great, very full and rounded. I am using a single stereo Masterclass (3300 GBP), but it can run out of power and I may upgrade to a mono pair (3300 GBP each, but the stereo can be converted to mono free). I think the Sugdens are a musical bargain, but many will be put off by the looksl.
I believe Wilson have upgraded the Watt mid-range and tweeter units, and these are available as an upgrade to existing customers (don't know the cost). Upgrading the 'tails' interconnect has also been advised by Wilson. I'm finding Wilson and the importers a bit uncommunicative at the moment (I'm trying to buy new foam grilles).
regards
I was aware that Wilson offered to upgrade Watt3s to full Watt V spec which involves a factory return, replacement of mid-range and tweeters and a rebore of the seating holes. I havn't a clue what it would cost - heart-stopping probably. Mine were modified from 3 to V before I bought them.
I heard they also offered to update the 'Tails' and to supply the acoustic diode spikes, again as an upgrade to the Puppy 2. Mine came with the spikes and MIT cables. I think for something like £800 they would swap the cables for Transparent he he he he!
I've never found the UK importers helpful, but i've telephoned Wilson and e-mailed them, always with polite and helpful replies, even if they won't tell me how to bi-amp.
To my ears, they still sound fabulous and despite NBLs and N802s comming along afterwards, I still haven't heard a speaker that I would swap to.
If (or when £££££) I aquire a more powerful amp, I will post a note about performance
Don
