Wireless vs. hard-wired internet connections
Posted by: Steeve on 13 June 2009
Ok, before we start I have to confess to a lot of ignorance on all this Distributed Audio stuff. But my question is this:
I understand that it is possible to wirelessly stream from a PC or Mac to the NaimUniti which sounds like a great feature.
However I thought I read that Linn don't recommend using their DS streamers wirelessly, insisting that better quality can be had from hard-wired ethernet connections.
So: is a wireless connection, although a nice feature, a compromise in sound quality? Or is there really no difference (assuming you have a reliable wireless connection)? Or have I completely misunderstood what is going on here?!
Steeve
Posted on: 13 June 2009 by David Dever
You need to consider the effects of capacity and latency, as quality of service (QoS), in order to gauge the suitability of wireless versus wired Ethernet connections.
If you have significant capacity (network throughput), with a limited number of connected clients, then you need worry only about latency (and buffer size).
One NaimUniti on a wi-fi network should be fine.
Posted on: 13 June 2009 by Steeve
I understood the last line at any rate
Posted on: 13 June 2009 by kuma
I think what he means is that there are too many things sharing the same wireless pipeline, there will be some drop off whilst streaming. ( at least that's how I interpreted it )
Posted on: 14 June 2009 by Former member
Providing you have a good signal, and there aren't too many devices connected and working at the same time, wireless is fine, which is the case in most domestic situations.
In terms of sound quality, there's no difference.
Posted on: 14 June 2009 by Merto
Does the same go for wireless downloads? i.e. is there any compromise in sound quality if say a WAV or FLAC file is downloaded wirelessly? (or is that what the question was????)
No, there's no difference, unless the device to which you're downloading reports an error, which is far more likely to stem from the internet side of your router anyway.
Posted on: 15 June 2009 by Steeve
Thanks for all the replies, even David's which on re-reading did make sense despite my ignorance of the technical terms!
Yes, my query was about sound quality rather than reliability of signal. It seems the consensus is that wireless is fine.
Steeve
Posted on: 15 June 2009 by james n
I just wouldnt want a wireless device in my rack (yes i have a Mac in mine but its hardwired and wireless and bluetooth are disabled). We take so much care to site equipment and dress cables properly and then put 2.4Ghz in close proximity. Wired and wireless will sound no different - but how a wireless device will interact with your hi-fi could make a difference to the final result.
James
Posted on: 15 June 2009 by Former member
James
Posted on: 15 June 2009 by Gary S.
Steeve
Steve
I have had some very recent experience of this very issue. I run a Linn Accurate DS which I use in conjuction with a netgear Nas drive. Recently I had a few problems with my NAS (caused by the software) which resulted in the NAS having to be returned my dealer to be cleared off and reset. Anyway whilst it was away I used a laptop as a temporary hard drive and this was set to stream wirelessly via the router to the DS and I have to be absolutely honest and say I could detect absolutely no difference whatsoever.
Now I have to eat hubble pie at this point and admit I was one of those who strongly stated wireless sounded crap, when somebody possed a similar question a few months ago. I admit I was wrong.
Posted on: 16 June 2009 by DaveBk
I've been using a Logitech (Slim Devices) Transporter wirelessly for a couple of years with no issues - if it's properly set up, I don't think there's any difference.
