AV2 and non Naim Pre Amp
Posted by: Neil Gilbert on 13 December 2007
I have until today run a 5:1 system consisting of AV2/300/145/200. Front duties were handled by the 300 via a 52.
Unfortunately I have had to downsize and have replaced the 52/Super and 300 with a Dynavector pre/power.
I have set this up with phono and CD but cannot work out if it possible to have a 5:1 system incorporating the AV2 and Dynavector pre using RCA connectors. I think I need to have a special connection between output 3 of the AV2 and a input on the preamp. My previous connection was din to din and no longer any use.
Hope this is reasonably clear and any help appreciated.
Neil
Posted on: 13 December 2007 by Mr Underhill
Neil,
Don't know about 'input 3'.
Take the main channel out to an input of your choice on the preamp.
Set the pre to a position you'll remember easily - 12?
Use the noise generator to set the levels on the AV2.
You're good to go.
I use a Chord DIN to stereo RCA cable.
I do this from the AV2 via my EAR864, no probs.
M
Posted on: 13 December 2007 by David Dever
The DIN to RCA phono interconnect needs to be wired from the record output quadrant of the 5-pin DIN.
The output on DIN input socket 3 tracks the AV2 volume–but I believe there may be an RCA phono output that also does this (must check).
Posted on: 13 December 2007 by AV@naim
Neil
Does the Dynavector have a unity gain input? If not its a case of changing the volume each time on the "AV" input
You just need to either:-
-modify your existing yellow banded lead to have RCA's on the non-banded end, at your own risk
Or
-obtain a 5pin din to RCA lead from us, via your dealer (that is correctly wired for use on AN3 output)
Posted on: 13 December 2007 by Neil Gilbert
I realise that I can connect as before by simply substituting the din to din lead from the av2 to 52 with a din to rca lead to my new pre.
My query was whether any of the rca connections at the rear of the AV2 could mimic this connection as I have two rca to two rca interconnects available.
Neil
Try the RCA phono record out, just in case....
I have a feeling that tape out is a fixed output level.
Whilst you could use it in this mode, you would have to compensate accordingly with the volume on the Pre-amp, as the AV2 would not control this output when the vol was adjusted.
–yep, fixed output (560R buffer) from analog inputs only.
