CDSII suspension
Posted by: Rockingdoc on 28 March 2001
Being a twit, I didn't read the instructions, and removed the transit bolts from the CDSII underside with the unit upside-down (this was always ok with the CDSI). It made a bit of a clunk, and now the suspension seems to grate if bounced even a mm or so. Should there be more free movement (my CDSI had loads)?
I don't really want to send it back to the factory if there is nothing wrong, so can you please advise if your CDSII has much free bounce.
