Do you really still need a NAIM pre amp?
Posted by: Geoff P on 05 January 2003
I am new to all this so bear with me if this is a dumb question.
With the introduction of the 5 series and the mixing of signal connections that's going on in such products as the AV2, does the old rule that you have to have a NAIM Pre-amp to drive a NAIM Power Amp still strictly apply to the 5 series products?
For example you are allowed to feed a signal from the pre amp stage of an A/V surround amp thru'the A/V input on a NAC 112 using "ünity gain" and then into to a 150 power amp which bypasses any pre-amp processing in the 112.
That sounds pretty close to driving the 150 with non-naim pre amplification.
Can anybody give me guidance on this question please
GEOFFP
Posted on: 06 January 2003 by graphoman
your query is a classic one. The answer is no way scientific but rather empiric: stick to the mainstream, the link “preamps” is mandatory and it have to be from Naim (in a Naim system). In some cases: in other systems as well. E.g. for some 5 years age I had better sound from an Audio Research amp when driven by a Nait (!!!) than by its own expensive pre.
graphoman
Posted on: 06 January 2003 by Ron Toolsie
Inspite of, or probably because of their relatively simple topology,and selective attentiveness to powersupplies,Naim preamps usually have no difficulty in standing head over shoulders with many/most equivalently priced competitors, and even a few far, FAR more expensive alternatives. A good portion of the naim signature sound passes pretty much unchanged even when using a non-naim poweramp with a NAC**.
To continue mining on the Audio Research vein, I found years ago that a 42/Hicap simply spanked their SP8 preamp (at 4 times the price) when used with their own D70mk2 power amp.
So you don't need a Naim preamp, but if you value the Naim signature sound, you will have a hard time recreating it without one.
Ron
Dum spiro audio
Dum audio vivo
I think you’ve got the point. Mine was a D70(I.), coupled with an SP6.
graphoman
Posted on: 07 January 2003 by Geoff P
Thanks for your input.
It looks like what you guys are saying is that most of the "character" in the NAIM sound is coming from the pre-amp.
I was assuming the power amp delivered the majority of the sound signature.
What is your opinion?
Posted on: 07 January 2003 by Rockingdoc
Most of the Naim sound comes from an LP12.
malcolm
Posted on: 07 January 2003 by Doug Graham
With an Aro.........
Big Grin
Posted on: 07 January 2003 by bjorne
And an Armageddon Razz
OK, OK Yes BUT:
I agree that once you get the all important sound signature from the particular "front end" of choice down thru' your cable of choice and admitting that when the amplified signal comes out of the NAIM gear it goes down another cable (which may be of choice or may be NACA5) into your speakers of choice you are already looking at a lot of effects.
Nevertheless when upgrading thru' the NAIM range some of you experts must have formed conclusions about the relative impact of the Pre-amp and the power amp on what you hear.
GEOFFP
Geoff.
I'm not really sure but I think the reason that Naim recommends not to use a Naim power amp with a pre of another brand has something to do with "bandwidthlimiting" in their preamps. This means that some other preamps might "upset" a Naim poweramp. However it's ok to use Naim preamps with other poweramps.
Regarding "impact" of pre vs. power most people would say that as long as you have a good source upgrading the preamp gives a better result than upgrading your poweramp. This is of course as long as you don't need more power to drive your speakers properly.
Bjorne
Posted on: 07 January 2003 by graphoman
IMHO
the Naim sound comes from any link of the Naim system. When my ARC burned down and I came back to an old 250 it was like meeting a good old friend. (And there were still no other Naim in the system.)
Just as any audio co. with good reputation has its own, characteristic sound.
graphoman
Posted on: 07 January 2003 by Bob Edwards
I personally think a lot--perhaps most--of the Naim character comes from the preamps (within the amplification--excluding sources). This is not to say that the power amps do not contribute to the overall character--they certainly do. I've heard a number of examples of Naim preamps driving other power amplifiers to great effect. Substituting a NAP increases the amount of character further, but not to the same degree.
Best,
Bob
