AV2 running warm...
Posted by: azjya on 14 February 2007
Feedback appreciated.
My three week old AV2 started running warm a couple of days ago - not too hot to touch but definitely warm, and in stark contrast to my CD5 / NAC 112 / FC 2 / NAP 150 none of which ever feel appreciably warm to the touch. The whole case feels warm - including the rotary control knob. It seems to be operating normally, however.
In other users' experience, is this normal?
I also have a buzzing noise when the NAC 112 is set to AV input - not very loud but very different to the relative silence when the input is switched to, say, CD.
Any thoughts?
DL
Posted on: 14 February 2007 by Former member
Any thoughts?
DL
It should not run warmer than the rest of your kit.Get intouch with your dealer.regards munch
Posted on: 14 February 2007 by Jay
My Av2 has always been warmer to the touch than any of my other Naim equipment. I think it's normal.
Does your knob get hot ?not a pun.regards munch
just had a feel Winker and it isn't. I don't know what DL's circulation is like.
regardless the Av2 runs noticeably hotter than any other piece of naim, which is what I said. do you have an av2 as well munch?
Posted on: 14 February 2007 by David Dever
Have you added anything to the system as of late (video or otherwise)?
No but looking into to it, a friend of mine has one and it runs as hot as the rest of his naim kit and he is in a very hot place.just a ? is it easy to run none Naim in to? regards munch
very easy. I have a cd5/fc2, telewest box, dvd player, ipod, airport express...
Posted on: 14 February 2007 by Neil Gilbert
My AV2 has always run warm.
I think a read another thread where the AV2 was described as a 'Hot Box.'
Neil
Posted on: 14 February 2007 by AV@naim
AV2 does run fairly warm under normal use...
Posted on: 14 February 2007 by azjya
Thanks for all the replies. The only thing recently added was a optical digital connection to an Airport Express. I noticed the warmth the next day. No other changes have been made and the only other input connection is coax digital from a DVD source (cheapo Sony pending arrival of Pioneer blu-ray player).
Curiously, the unit felt cooler after being used for an hour or so than when I left it in standby overnight and rechecked it in the morning - rather warm again.
Would welcome continuing to hear from other users regarding this issue.
In the meantime, another question. I understand that the signal from a source (say, my CD5) connected to my 112 can be fed to the AV2 to allow processing with subsequent multichannel output via the special "2 way" lead that came with the AV2. Didn't see this explained in the manual. How do I actually do this?
Ta
DL
Unit may run warmer when processing audio
You need to use the yellow banded 5:5 interconnect lead supplied with the unit
connect from AN3 input on AV2 to the 112 AV input (set unity gain, so that the AV2 controls volume)
