Problems with CD replay on PC - Help please!
Posted by: Clive B on 01 April 2010
In January I purchased a new PC (my first with an AMD processor). I am using the excellent 64 bit Windows 7 (and the dreadful Office 2007 - why did they have to change the old toolbars?).
This week I tried to copy a CD to play in the car. The process seemed to take a long time and when it was finished, although it appears the CD recorded correctly, there was dreadful noise / distortion on the recorded disc. It sounded like someone was frying eggs and amplifying it through the speakers.
I then tried just playing a CD which sounded just as bad. Obviously, the noise occurs when the CD is being read or in the signal processing. The CD also skips and/or jumps (rather like when you have a greasy disc or puck in a Naim player). I have tried various CDs. Some are fine, but about 50% exhibit this problem. I encounter the same noise on both Windows Media Player and Roxio. I have also tried one DVD which worked fine in Windows Media Player.
I am in contact by e-mail with the manufacturer, who having suggested some software / BIOS updates is now suggesting a change of optical drive.
Does anyone on this forum have any idea?
This is a most frustrating problem, so all ideas welcomed!
Thanks, CB
Thanks, CB
