av2 remote +lowe planus tv
Posted by: Himat on 20 June 2003
My AV2 remote seams to interfear with the tv
ie if dsp pressed on av2 the tv switches off.
also not sure which keys i pressed on av2 remote turns the sound off on tv and i cant get it back until i do a rest on the tv.
tv is lowe planus 4681z
any one
any one
Posted on: 20 June 2003 by Manu
This is a known problem, call your dealer or Naim they will fix it.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Emmanuel
Posted on: 20 June 2003 by Himat
hi manu
how is this fixed
how is this fixed
Posted on: 21 June 2003 by prowla
Aren't Naim CD players based on Philips?
Posted on: 21 June 2003 by bjorne
Prowla, yes they are based on Philips transports.
Posted on: 21 June 2003 by Richard Dane
Himat,
speak with your dealer. He can supply you with a special modified remote for the AV2 which has a choice of 10 code sets to avoid conflicts with the codes used on Loewe TVs.
Rod,
Again, speak with your dealer. We can supply him with a new control chip for your pre-amp to avoid conflicts with SKY+ remote codes.
Richard
Rod,
Richard
Posted on: 22 June 2003 by prowla
Richard
It's good to know that the codes can be changed.
I've been thinking of Sky+, but the possible conflicts have made me a bit wary.
Is the upgrade FOC?
(I've got an 82 and CDX.)
Paul
Is the upgrade FOC?
Paul
Posted on: 22 June 2003 by Stuart M
Also had conficts with my NAC102 and a pace twinview harddisk freeview decoder/recorder
To err is human; to really foul it up requires a computer.
Posted on: 22 June 2003 by Himat
Richard
thank you for your reply i will speak to my dealer .
Posted on: 23 June 2003 by Richard Dane
Stuart,
I believe I'm correct in saying that Pace make the SKY+ box so it's likely that the modified control chip will also cure any code conflicts with the Pace Freeview hard/disk unit.
Richard
Posted on: 23 June 2003 by Stuart M
Thanks Richard,
Will talk to my dealer and get it sorted
Posted on: 23 June 2003 by Martin Payne
Stuart,
how do you find the twinview? I'm quite tempted by this myself.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
