552 -six months later
Posted by: RICHYH on 30 June 2003
After installing the 552 6 months ago, I stated how after a couple of weeks you wonder if its any better because you get used to the sound.
Well 6 months later and with the spur well and truely run in, I can honestly say I never thought it possible for a system to get this good, its just unbelievable how much it does. It plays delicate pieces with refinement and great image but also the rythem and power of bass and drums is wonderful.
After 20 years of listening I thought systems could not do both but it does with ease, its fantastic with ALL music.
I do now feel the enjoyment/appreciation from music does increase the better the system gets.
Posted on: 30 June 2003 by Kevin-W
Nice one...
Quick question: what is/are your source(s), power amp (500 I presume) and speakers?
Kevin
Posted on: 30 June 2003 by Rasher
and of course it sounds so good, you simply must upgrade it to something else... Big Grin
Posted on: 30 June 2003 by NB
Glad to see your enjoying your sistem Richy, isn't that what its all about?
NB
Posted on: 01 July 2003 by RICHYH
Hi Kevin,
I use a Well Tempered reference with Clearaudio insider refernce and groove plus front end, I use 6 Audionet mono to drive NBLs active.
