Naim Nait 5 as power amp ?
Posted by: speffy on 29 January 2010
Hi !
I would like to use my nait 5 as a power amp in my 5.1 system. Im a little bit confused how i should do with the link plug at the back.
Should i remove it and dont use it at all if I want to use my nait as a power amp ?
Now its linked between Input and Signal B Out.
I hope anyone can help me out!
Posted on: 29 January 2010 by BigH47
Take out the long link and connect to the Input. That is what seems logical, of course as usual the set-up you want is not shown in the manual.
Unless Richard comes to the rescue I'd e-mail to HQ,link on the Main Website, tell them what you want to do and what you want to connect.
Posted on: 29 January 2010 by djh1697
I would agree, the mains lead would also need to be plugged in of course.
Posted on: 30 January 2010 by speffy
Thank you guys!
You were right, I email naim and they told me to remove the link plug and connect Input to pre out on my receiver.
Posted on: 30 January 2010 by Richard Dane
Speffy, you can do it the way you have done already, or you can use the AV input set to Unity gain.
Posted on: 06 February 2010 by speffy
Now I connect my nait 5 to my receiver.
4 pin DIN-RCA between Input on nait to pre-out on my receiver. Nac5 from nait to my RX8 speakers.
It works but there are no green light from my nait anymore, should it be like that ?
Posted on: 06 February 2010 by rich46
this additional information should be in an compehensive manual/
The manual doesnt say anything about the light thats why I wonder if its normal.
