n-vi and component cable
Posted by: john R1 on 30 March 2006
have read somewhere bnc to rca adaptors are not to clever, anyone suggest a resonable rca to bnc component cable for my n-vi to my pw6b,
no rush
Posted on: 30 March 2006 by Roy Donaldson
This guy does some alright stuff:
http://www.markgrantcables.co.uk/
Have a look and see what you think.
Roy.
Posted on: 30 March 2006 by john R1
thanks for the reply roy, but they seem to have sold out of most popular ones ?
Posted on: 30 March 2006 by Frank Abela
John,
A Chord Co. dealer will be able to order you one of those.
Posted on: 31 March 2006 by Vaughn3D
I am using these cables for my Arcam DV78 to pwD8 with nice results. The 1694A cables are a good choice. You can order custom lengths with either BNC or RCA at either end.
http://www.bluejeanscable.co.uk/index.htm
Posted on: 02 April 2006 by john R1
vaughn they still list that cable in stock at mark grant, do i need bnc to rca or rca to bnc i can only assume these are directional, as they state on the site the two options,
Posted on: 02 April 2006 by jasons
Shame really as i just sold my wireworld bnc to phono cable that i was using on my dvd5 on fleabay. And a damn fine cable it is too.
At the end of the day, it also depends how much you are willing to spend.
Jason
Posted on: 02 April 2006 by Roy Donaldson
Regarding the bnc to rca / rca to bnc. I've spoken to Mark about this previously and it's purely cosmetic regarding which way the writting on the cable goes etc.
(I do have a bnc to rca and rca to rca spare at the moment. Perhaps best to contact me offline however.)
Roy.
how do i reply to you off-line roy,
rdonalds at cisco dot com
Posted on: 06 April 2006 by Vaughn3D
JohnR1, sorry for my slow response. The bluejeans cables are not directional. The rca/bnc and bnc/rca options will give you the same cable.
Posted on: 06 April 2006 by john R1
vaughn, spoke to my dealer and he suggested using my decent rca cable via bnc addaptors first, so will only buy a cable if i need to, thanks anyway
Posted on: 11 April 2006 by bwolke
I use a van den Hul Compolink to connect my Arcam dv88 plus to my parents plasma. It gives an excellent picture and can be fitted with RCA or BNC plugs.
