replacement n-vi
Posted by: john R1 on 14 October 2006
received my new n-vi on wednesday, so far so good, no problems with the optical input fed from my tv-drive, like there was with the first one and to some extent even after the software upgrade, just hoping they manage to sort out my dvd-audio problem which they know about, by the way it is only one dvd-a disc that it has problems with. would now highly reccomend buying an n-vi if you are looking for a one box solution.
Posted on: 14 October 2006 by Former member
Hi John thank god for that. at last a happy man and wife.kind regards munch
Posted on: 14 October 2006 by David Dever
Which DVD-A disc?
Posted on: 15 October 2006 by john R1
david, its the tubular bells 2003, played this before on my arcam dv-89 and it was ok, but on the n-vi you get long pauses between the tracks which were not there on the arcam, have a few other dvd-audio discs which all work fine,
Posted on: 15 October 2006 by David Dever
thnx
david, just to add to my previous post, i had another look at the disc today, it says there is a dts multi surround format on it as well, but i can't seem to access it, all that comes up on the disc menu is suround or stereo, whichever i select goes into mlp either surround or stereo, tried to select something differant on the n-vi but that just comes up the same.
Posted on: 15 October 2006 by Former member
Hi John where did you get the disc from? regards munch
hi munch, i think i bought it from play.com
Hi John if you got from play it will not be a copy its just one or two sites u can get copies sold as the real thing and they dont have all the info on the disc. Ihave only one disc my n/vi wont play and thats a cd tangerine dream that comes with the dvd live in america 1992dvd+ cd collectors edition .I did a copy for the car and that plays ok in the n/vi.regards munch
munch, just put the disc in my boys dvd player and because its not a dvd-audio player it comes up with the choice of dts or dd 5-1, not sure how to get this up on the n-vi, any ideas ?
just going to try something . will get back to you in a few mins .munch
just gone through my dvd audio discs not one has dts just 5.1 i have three m. oldfield dvds bells2-bells3 and millennium bell live in berlin. if i was you i would not bother with dvd audio discs .just get the dvds and turn your plasma off or record them onto cd.regards munch.
Posted on: 16 October 2006 by AV@naim
does the disc work ok in other multi channel capable players?
(This may be a mastering error).
Posted on: 16 October 2006 by john R1
av@naim, just tried in my boys computer the dd 5-1 surround format works fine, not even any pauses between the tracks, i know that the advanced resolution surround works without any pauses as it used to play on my arcam dv-89, i dont have anything i can try the dts soundtrack on, as my n-vi does not give me the option to try it,
