Harsh treble.
Posted by: fled on 20 May 2003
This is not the first post on this by me, but I am narrowing down the cause I think, your comments/ help will be greatly appreaciated.
System CD5+HI 102+HI+Napsc 180 Dynaudio 1.1 + NACA5 in a big room (4m x 8m)
Problem - Harsh treble at 9oclock and over on the volume dial, unfortunate as my ideal listening is 9 to 10 position. Bass and mid range are fine.
My initial thought was its the cdp or cable(due to a replacemnt CD5 and upgrading to NACA5 from QED)but thats know bedded in and gives good results until that 9 oclock position, so what can i do, is it the Dyns ? is it the 180
if I go to a 250 will this help or will it infact make matters worse. I have a pair of Dyn 42,s (rears in a 5.1 set up) that I can try but this seems a downward step ?
I suppose the question is next upgrade ?
1. better cdp
2. 180 to 250
3. 102 to 82
4. Change the speakers (dont real want to do this as I love them)
Overall I love the system but this harsh treble is getting me down
Phil
1. better cdp
2. 180 to 250
3. 102 to 82
Phil
Posted on: 20 May 2003 by hi fi fo fum
what ends do you have on the NacA5 ?
Posted on: 20 May 2003 by fled
naim at the amp and QED airlock at the speaker
Posted on: 20 May 2003 by Rasher
I have been told that when a power amp needs a service or recap, the treble can go harsh. 10 years (ish) I was told yesterday.
the power amp is 6 mths old
Not that then...
Posted on: 20 May 2003 by Phil Barry
Sounds like it could be lack of power - can you borrow a 250? or 135s? Will the budget allow a 300 or 500?
Regards.
Phil
Regards.
Phil
Posted on: 20 May 2003 by --duncan--
Phil,
Lots of possible reasons for this and I think changing boxes should generally be a last resort. Other people will no doubt (and should) talk about mains supply, set-up and supports.
How is you room furnished? Your room-speaker relationship (not the technical term I'm sure, but the two have to get along!) may be an important factor.
I had a similar problem to you. The music would only take life at 8.45 but was getting harsh by 9.15. This problem was completely eliminated by a thin rug over a radiator behind the speakers. The room is still quite 'live' (wooden floor) and I was surprised at what a difference 2 square metres of fabric made.
duncan
Email: djcritchley at hotmail.com
duncan
Posted on: 20 May 2003 by leeto
Recently, I played tracks 7 and 8 of the XLO test disc 3 times for sistem demagnetisation. My jaws dropped when suddenly the treble harshness that was in my sistem went away immediately. The basslines also improved by a significant margin. Worth giving it a try and let me know the results. A few of my friends also had positive results on non-Naim sistem.
http://www.amazon.com/exec/obidos/tg/detail/-/B0000015AL/ref=m_art_li_1/102-6832140-9042519?v=glance&s=music
ok I know this will start a long thread but when you say dedicated mains spur, whould a ring main with only the Naim gear attached to it be the same thing ?
or is it the marble fireplace between the speakers !
Posted on: 20 May 2003 by mathew farley
I've got to be very carfull here to try not to upset anyone but basically im not a fan of dynaudio speakers
I used to have a sistem very similar to yours: Cd 3.5/Hi-cap, 102/Hi-cap, Dynaudio 1.3 se and Nac A5
It had amazing detail in the treble and bass but just did'nt do it for me. They also sounded fatiguing at high volume
I've got the same electronics but now with epos es 11 speakers and am much happier
Posted on: 21 May 2003 by hi fi fo fum
Fled if your system is set up right and there are no other problems , stands ridged ect, cut off the Qed air locks and try bare wire into the speakers...I find the QED connects to be edgy
Posted on: 21 May 2003 by Greg Beatty
I read on Audioasylum that the tweeter used in Dynaudios can offer up excess energy in the frequency range where sibilance lives. Two remedies:
* Add a felt ring around the tweeter
* Add a layer of tissue paper over the tweeter (additional layers for additional attenuation - old studio monitor trick)
Of course, if there is a problem upstream, this will not address it.
- GregB
Insert Witty Signature Line Here
[This message was edited by Greg Beatty on WEDNESDAY 21 May 2003 at 15:25.]
- GregB
Posted on: 21 May 2003 by Mike Hanson
That harshness that you describe was the last big thing that was bugging me about my system. At lower volumes it was wonderful. At higher SPLs, though, that hard/harsh sound would drive me batty. Here's what I did:
All of the above improved the problem with harshness. (Step #1 got me only half way there.) Now my system's only limitation is maximum volume. I can get the Albion's woofers popping before the harshness bugs me. Heed this advice, and you might get the same level of satisfaction.
-=> Mike Hanson <=-
- Upgraded my gear until CDS2/52/Super/2*135/RoydAlbion. (Don't laugh! This was one of the main reasons I kept upgrading. In the end, I don't think this was the "best" route to solve that particular problem, but it did result in a very nice system. The following points are a little more reasonable.
) - Installed two dedicated, 20-amp mains lines. One is used for the CD player, while the other has a power bar with the rest of the gear.
- The power bar is similar to the Wiremold power strip; essentially it's a Hammond power bar converted to use Bryant spec outlets, and no switch.
- I replaced the ground clamp on my water pipe, because the old one was very corroded.
- I rewired the internals of my Albions, so that both speakers shared the same binding posts, eliminating the need for a strap between the binding posts. (Prior to that, I had tried changing the stock brass strap to copper, and then changed to an "F" configuration with two sets of plugs on my cables. Both of these improved the situation, but neither as much as using the single set of binding posts.)
- Changed the connector at the speaker end to Ecosse Z plugs. This was surprisingly good upgrade.
-=> Mike Hanson <=-
Originally posted by ghunter:
I'm getting the same harshness problem with CD5/62/hicap/180/Credo, and am really wondering what to do. I keep on telling myself that a preamp upgrade will do the trick, but after reading Mike's post I'm not sure that's going to get me all the way there.
Actually, I've found that the 62 is a bit edgy sounding (kind of like the 42.5), so upgrading to a 72 or 82 would improve it quite a bit. It won't take you all the way there, though.
One thing I didn't mention in my prior message: the supports also made a big difference. I'm using Mana, and adding that really cleaned up the signal.
-=> Mike Hanson <=-
Posted on: 21 May 2003 by Wiltshireman
Just a couple of comments.
1. I doubt if it is the power amp causing the problem though if the speakers are difficult to drive then it is pos that it is being caused by a lack of power.
2. Try Chord Solid interconnect between cds and pre amp. Personaly I would try this first as a previous similar experience was sorted using this this cable.
3. Are the speakers normally bright? I don't know this range but other comments I have read indicate them as a pos cause.
I would start with the cable a go from there if I were you. Try a good dealer or even chord themselves, ie e mail their cable doctor and ask his opinion.
Posted on: 21 May 2003 by Mike Sae
I can confirm this. The only way I could tell that I was playing Mike's sistem at blistering levels was when Mike told me "you're playing the sistem at blistering levels".
I think the knob was at about 11:30, IIRC.
Posted on: 21 May 2003 by ClaudeP
Fled,
When I used to sell hi-fi (about fifteen years ago!) a concept called "single speaker demonstration room" was very popular, and I for one was able to demonstrate its pertinence quite a few times.
Simply put:`the presence of any other speaker in a listening room degrades the sound to a certain extent. Therefore I have to agree with J.A. Toon: getting speakers positioned optimally for both Hifi and AV is quite difficult.
(By the way I have yet to hear a system sounding great with a TV set in the same room -TV's seem the utmost challenge to good sound.)
Have you tried listening to your system without the TV set in the room? Does it do any difference?
Posted on: 22 May 2003 by Mike Hanson
Believe it or not, Mike, I still felt that there was too much harshness at that time. My system is much better now (although the woofers still won't let me go higher, which is the only remaining issue, albeit a small one
-=> Mike Hanson <=-
Can you just add Mana platforms to an existing stand, or does it have to all be Mana?
Assuming that your stand is VERY stable, you can use a Sound Frame on an existing shelf. It adds about 3-inches to the height requirements, though. It's not as good as going full Mana, but it is an improvement. (BTW, my first foray into the Mana world was a simple Sound Frame on an existing oak entertainment unit.)
-=> Mike Hanson <=-
Posted on: 22 May 2003 by Frank Abela
Fled
There are several things which I do not like the look of in your setup, so let me preface what I am about to say with the usual caveats of taking the WAF factor into consideration!
I know Dynaudios quite well and you have them setup about as suboptimally as possible.
Ideally:
1. They like to be closer together than further apart - in your room about 6 feet apart should do.
2. They do not like being toed in. This causes a pinched narrow perspective very often, although in your case, with them being so far apart this is unlikely to happen.
3. They need a decent stand. I see you're using the entry-level Atacamas. The Dynaudio Masterstands are really the ticket with all Dyns, but especially in the Contour range. Those Atacamas won't be able to handle the energy coming out of a pair of 1.1's.
4. Somehow (and I don't know why) HiFi's sound better if they're not placed between the speakers.
So, given the ideals, what can you do?
1. The right hand speaker should at least go in between HiFi rack (oh my Gosh it's a Stands Unique!) and TV. You need at least 1 foot away from the TV since they're only part shielded. This would also allow you to have the speakers in a more dead-ahead position (you may still have to toe in, but only slightly). This will bring benefits in terms of scale pace and cohesion - you may find 10 o'clock to be too loud if you do this!
2. Borrow a pair of Dynaudio Masterstands from your friendly neighbourhood dealer. the difference should be remarkable.
3. The Stands Unique could be helped a little, especially if it is the 6mm variety (it comes in 6mm and 10mm glass variants). Try putting dampening materials on each shelf in the rack. Sounds technical, but what I mean is try a hand towel under each piece of equipment and see if it makes a difference. If it does then you know the rack is contributing to the harshness and you can try dampening it down with proper dampening things like blutak etc. This would also lend the argument of moving the right hand speaker a lot of weight.
4. When you play music, do you leave the TV on standby? If so, switch it off at the mains or at the switch on the front of the TV. A layer of harshness should be removed. This will be subtle but you should hear the difference.
Dynaudio 1.1's are difficult to drive and will sound harsh if the amp isn't up to the task. However, I don't believe that to be the case in this scenario. Although it's a big room, the listening position is no more distant than average. Also your listening level isn't that high if it's 9 - 10 o'clock. This is more a function of setup than a mismatch of equipment in my view (apart from those Atacamas). Try the cheap options I mentioned (try the towels first) and that should help you identify where things are going wrong. Then move on to the stands option if nothing else works.
Finally and only for completeness, you may wish to consider buying a Quadraspire centre speaker stand which has built in angles allowing you to have the centre speaker aiming up a little. It's so low that it needs the help.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Frank.
Posted on: 24 May 2003 by fled
Frank.
Thanks for all your suggestions, things are starting to improve
1. I have moved the RH speaker, not unfortunatley to 6ft more like 7 and a bit (WAF) and reduced toe in this has improved the overall presentaion, but not alas the harshness, then i tried putting the covers on the dyns (an earlier suggestion) BINGO smoothed out no end, could it be as simple as this ?
I have 10mm glass but will try the tweek to see if it improves even more, likewise the stands I will try to demo a pair ?
Through all of this I have noticed someting strange as the improvements occur the Hicaps lost there buzz from the transformer, does this point at cleaner mains, and thats the real reason for improvement ?
Phi
Phi
Posted on: 25 May 2003 by syd
Good news Graham.
I now wonder what the "cable directionality is a lot of hokum" crowd will make of it?
Yours in Music
Syd
Yours in Music
Syd
Posted on: 26 May 2003 by Frank Abela
Fled,
Putting the grilles on the speakers is a little drastic. You will lose more clarity and detail than one would wish - a bit of a sledgehammer to crack a nut. Of course, it works in the meantime, but I would try the other options and check the cable directions (forgot that one).
Frank.
Frank.
Posted on: 07 June 2003 by fled
ok I have tried.
1. New speaker stands (Partington Dreadnoughts)
2. Isolators under all the glass shelves (Stands unique 10mm)
3. Grilles on the Dyn 1.1
Is it any better - No
My dealer is willing to lend me a Isotek cleanline or min sub will this help or hinder ?
I would love to redo the mains but thats out of the question.
So thoughts on the Isotek would be good. I havnt the funds to extend to a qube.
CD5 +Hi, 102+Hi+Napsc 180 + Dyn1.1
