Moving a CD3. Where does that piece of "essential" plastic go.
Posted by: Shayman on 12 December 2001
Hello
I'm moving house this weekend and have finally found that CD tray-ish shaped piece of plastic that comes with the CD3 but can't work out how to fit it. As it states that it is essential to fit this thing before transit to avoid damage I'd be v. grateful for any help (or scans of one in place if at all possible!)
Does the hole in the plastic go over the lens or do you cover the lens with the double thickness part?
Is this really necessary if the transit screws are in place anyway? Hope what I've said makes sense.
Jonathan
