Playing with a 250
Posted by: Jonathan Gorse on 17 February 2002
Borrowed a 250 for the weekend from a local dealer with a view to replacing my existing 180 in CDI/102/HICAP/NAPSC/SBL.
Initial impressions are favourable with more detail and a better balance between bass and treble ie more bass and a bit less treble harshness which has been the major complaint with my system since adding SBL's.
I'm also considering re-setting up the SBL's possibly with the wadding in the bass chamber pressed down a bit more to give a larger area of free space to load the bass driver. From memory I think Naim say 7-10cm from the top of the lower cabinet. Will it make a difference if I go for 10cm?
Has anyone experimented with wadding height - could this be the variable which leads some to conclude SBL's have too little bass where others proclaim they have superb bass power.
Interested in views.
Jonathan
