n-Vi and active system (2 nap) without nac ?
Posted by: nicolas7 on 21 August 2007
Hello
The active system is possible with n-Vi and two nap (150x or 200 or 250) , snaxo242 and power supplie (HiCap or FlatCap) with front loudspeaker Naim Allae ?
Right or wrong ?
What are a cables ?
Thanks.
Posted on: 21 August 2007 by David Dever
You'll need the following cable to the power supply:
03-003-0146 (Interconnect Lead, 5 Pin DIN 180o to 4 Pin DIN)
It does work (having obscenely tried SUPERCAP2 / SNAXO362 / 3 x NAP250-2 / DBL at one point), albeit a bit unbalanced relative to the center channel and surround amplification / loudspeakers.
Posted on: 21 August 2007 by nicolas7
Ok
The active system with n-Vi can exist . Great
03-003-0146 is a Naim reference of the cable ?
This cable (interconnect lead 5 pin Din 180° to 4 pins Din is a same for ? :
- n-Vi with Nap 200 ( passive system ) .
- n-Vi with Snaxo242 ( active system ).
