n-sub connection to AV2 and SuperNait
Posted by: Ian P on 02 November 2007
Hi,
Quick question which doesn't seem to be answered in the FAQ section...
With my setup which is for both 5.1 and 2.1 purposes, how do I connect up the n-Sub?
Posted on: 02 November 2007 by David Dever
You'll need three long RCA-RCA leads, two of which connect to the SUPERNAIT (stereo use) and one of which connects to the AV2 (.1 / LFE use).
The stereo leads should feed the AUX input on the nSUB, with the single lead feeding the AV input, IIRC.
This will allow you to optimize the nSUB wit different presets for music (two-channel) and movie effects, let alone multichannel music....
Posted on: 02 November 2007 by Adam Meredith
Alternatively, you could make the 2 channel connection at high level from the rears of the speakers.
Posted on: 03 November 2007 by Ian P
David,
Thanks - that's what I thought might be te case. However, what stops the n-sub then getting input from both AV2 and SN simultaneously?
Adam,
Thanks also, but I don't understand what you are suggesting!
Ian
Posted on: 03 November 2007 by hungryhalibut
You simply switch between aux and AV inputs using the sub remote.
Nigel
Posted on: 03 November 2007 by Adam Meredith
Have a read of the relevant section in http://www.naim-audio.com/download/man_speakers_2004.pdf . It may give you a better idea of how the n-SUB works and the options available.
Each preset can be set for a different input - with other associated parameters stored for each.
