Best speakercable for my Nait 5i
Posted by: Jon K. on 07 February 2007
Hi
I need advice with speakercable for my system.
My current system:
Nait 5i
CD 5i
PMC GB1 small floorstanders
(transmissionline,87 db)
NAC A5 speakercable
I mainly listen to jazz.
I know many of you will advice me to stick with
the NAC A5 cable, but im just wondering if there
might be a nother cable that could do better.
I find the sound at present to be a bit rough in the treble and quite bright.
The bass is a bit weak as well.
Does it take very long to burn in the NAC A5?
What speakercable are you guys using?
Sincerely
Jon
Posted on: 07 February 2007 by Jon K.
Sorry, should have posted this in Hi-Fi corner.
I will do that know
