Flatcap1 to CD5
Posted by: domfjbrown on 30 January 2004
Dumb question - which socket on a Flatcap 1 should be connected to the CD5??? I guess this'd be described in the manual for the Flatcap (for the CD3.5??) - but I guess the procedure would be the same?
I hope they're both compatible anyway 'cos I've just acquired one... Wink
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
Posted on: 30 January 2004 by Richard Dane
Dom,
it's Socket 4 on the Flatcap, the only one that's a 5 pin DIN. It connects in exactly same fashion to the CD5 as it does with the CD3.5 and is perfectly compatible.
Richard
Posted on: 31 January 2004 by domfjbrown
Thanks Richard - assume it's all in the manual, but I won't know that until tomorrow Smile
Looking forward to getting this into the system though Wink
